@leelynds said:
@zpaolo11x — my friend, with your last two posts, you have defined the various video resolutions almost exactly the way that I suggested a few pages back. In fact, you second post even disagreed with your first one, and you said a 720X404 should not be 576p or 480p but SD. Exactly what I said.Why are we arguing, again?
We are discussing, not arguing ![]()
My post is not “disagreeing” with the first one: in that post I said 720x404 can be labeled “SD” if we want to be super strict with a 576p definition (so ditching cropping and the concept of vertical lines definition as a 576p defining factor), but if we are using a list of resolutions and AR to define 576p, then I’d say 720x404 (at 2.54) can be considered 576p too in light of the concept of "preserving the vertical number of lines of a 576p frame.
And yes, you already listed the resolutions, but I’d point out that, without AR information, they are not complete. Also, I listed the resolutions as an easier, although less elegant, alternative to my method of multiplying vertical numbert of pixels by aspect ratio and see if the result is 1024 or 854 ![]()
