@MovieFan.Plex said:
Let’s do it this way. Can you give me a table of the resolution ranges that should be used for the various labels? We’re not looking at just 1 resolution. If you want to argue 720x480 should be 480p, that’s fine. But we need a cutoff for when it’s no longer considered 480p. It would be a lot easier if every file fit a specific resolution, but we’ve seen 722x480, 720x482, 800x480, 800x420, etc.
722x480, 720x482, 800x480, 800x420, etc., would be improperly encoded files. I mean if you’re asking - that’s the truth. If Plex misreports them have them come and ■■■■■ about it on the forum - I’ll handle those. lol
No, really this is what I think and thanks for asking.
722x480, 720x482 - OK… a little padding - it’s still wrong, but Plex is all about the user (right?) and nobody is perfect (all the time - like me). A DVD can only hold 720 (the industry standard). Plex will give you 722 and maybe 485 then you’d better come to the forums for a lesson.
800x480 - The encoder fumbled the hand-egg and is kicking it every time he reaches down to pick it up. 576p Get over it. Come to the Forums.
800x420 - Give me a break - SD. Wanna know why? Come to the forums. I’d say 470 would be the SD cut off. If it ain’t 480 you’re doing it wrong and if it ain’t 470 you’re really doing it wrong.
720x404 - I know a guy that does that (even after I told him it was WRONG!) SD. He knows it’s wrong and loves the letters S and D.
There you go. I think most people would agree that would work for them.
And BTW - every single NTSC DVD I’ve ever seen carries 720x480. I have seen a whole bunch of 704x480 and every single time it’s from something I recorded from an OTA TV Signal - so yes, 704x480 should be 480p. I’ve also seen a LOT of horrible encodes, malformed aspect ratios and such coming off TV Broadcast Towers and that is due to being at the mercy of Educated Idiots (College Graduates) with ZERO real world, on the job experience and I have developed a whole bag of tricks dealing effectively with the disasters they pump into the airwaves.
If Plex is trying to chase these idiots to make Plex DVR work better - they’re making a big mistake.
