Why is PMS constantly stopping?
Server Version#: 1.18.6.2368
Can someone look at my logs and tell me why my PMS is constantly stopping. Everything was running fine for a couple of years and in the last 4 or 5 months the server stops working about once a day. Plex Media Server Logs_2020-03-26_18-37-39.zip (4.7 MB)
Verbose logging is off but I must have done it after the log dump. I’ll post the logs after the next failure.
I don’t run VideoStation and, as I mentioned, everything had been working fine for a couple of years. Until this started happening I had never had to restart PMS because it had stopped running.
Same issue happens to me too for about several weeks. I run usual package, not from Docker, I do not have video station enables, my video is on separate share folder named Media.
Can you also verify you have DEBUG logging enabled, VERBOSE disabled, then capture the logs when it fails and attach the ZIP file here ?
So here are the logs with verbose logging turned off.
Plex Media Server Logs_2020-04-13_16-06-46.zip (4.0 MB)
As for me issue did not reproduce for a while
