Why is video jumping with PMS on Synology NAS?
Server Version#: 1.18.2.2029-36236cc4c
Player Version#: Web Client 4.8.4
Plex Media Server Logs_2019-11-16_12-53-58.zip (3.2 MB)
Plex Media Server Logs_2019-11-16_13-06-55.zip (3.3 MB)
My setup is that I have a Synology NAS DS418Play with PMS installed. I want to stream BluRay content to devices in my home. The NAS has its supplied Ethernet cable plugged into my router. My desktop PC, in the same room, is also plugged into my router via another cable.
I have the movie Argo in a MKV container. According to Plex, it’s 1080p (H.264) and no subtitles. When I try to play this on my PC’s Chrome browser, I can see the NAS CPU briefly spike and then fall to more normal levels. But every 5-7 seconds, the movie skips a second during playback.
For Web Client - Quality, I have “Automatically Adjust quality” and “Use recommend settings” checked. Video quality dropdown is set to Maximum. “Play smaller videos at original quality” isn’t set. I’ve tried changing these but it doesn’t seem to help.
For Transcoder, quality is set to Automatic. I tried “Make my CPU hurt” but it didn’t help. The second set of logs should include my attempts to change Transcoder settings.
Do the logs reveal what’s causing the jumpiness in playback? Are there additional settings I can try to smooth this out?
Thanks for any help!
I tried getting a Plex Pass, wondering if HW transcoding would help. But I’m still seeing playback that skips. I’ve attached a fresh set of logs; see 11/18/2019 around 9 PM - I’m attempting to watch Argo. Can anyone help debug why I’m seeing choppy playback?
Plex Media Server Logs_2019-11-18_21-14-23.zip (3.8 MB)
From what I can see, PMS isn’t picking up on HW transcoding being present.
Nov 17, 2019 13:52:43.839 [0x7f7761cd7700] DEBUG - Starting a transcode session y258dbuuur8agn01x65lcshp at offset 42.0 (state=3)
Nov 17, 2019 13:52:43.839 [0x7f7761cd7700] DEBUG - [Universal] Using local file path instead of URL: /volume1/Media/Movies/Looney Tunes/Duck! Rabbit! Duck!.mkv
Nov 17, 2019 13:52:43.840 [0x7f7761cd7700] DEBUG - TPU: hardware transcoding: zero-copy support not present
Nov 17, 2019 13:52:43.840 [0x7f7761cd7700] DEBUG - Job running: EAE_ROOT='/volume1/Plex/tmp_transcoding/pms-37e100a3-0a59-4e74-b533-d21d392a1297/EasyAudioEncoder' FFMPEG_EXTERNAL_LIBS='/volume1/Plex/Library/Application\ Support/Plex\ Media\ Server/Codecs/395e79c-2735-linux-x86_64/' XDG_CACHE_HOME='/volume1/Plex/Library/Application Support/Plex Media Server/Cache' XDG_DATA_HOME='/volume1/@appstore/Plex Media Server/Resources' X_PLEX_TOKEN='xxxxxxxxxxxxxxxxxxxx' '/volume1/@appstore/Plex Media Server/Plex Transcoder' '-code
Did you restart the server after activating the Plex pass on this account?
Also, did you go to Setings - Server - Transcoder - Show Advanced and enable it?
I just tried restarting Plex and it didn’t help. Further, I did confirm Use HW Acceleration is checked. Also please note I just did this but the log snippet you showed is from two days ago. I’m using Manage -> Troubleshooting to provide logs; I’ve attached a new copy.
Plex Media Server Logs_2019-11-18_22-14-08.zip (3.4 MB)
Thanks for the updated logs.
Is this in a docker container or VM ?
I ask because the hardware isn’t showing (notice the TPU lines) but the CPU has the ability.
Nov 18, 2019 22:11:02.493 [0x7f2fc2f26700] INFO - Plex Media Server v1.18.2.2029-36236cc4c - Synology DS418play x86_64 - build: linux-x86_64 synology - GMT -08:00
Nov 18, 2019 22:11:02.493 [0x7f2fc2f26700] INFO - Linux version: DSM 6.2.2.24922-4, language: en-US
Nov 18, 2019 22:11:02.494 [0x7f2fc2f26700] INFO - Processor Intel(R) Celeron(R) CPU J3355 @ 2.00GHz
Nov 18, 2019 22:11:41.616 [0x7f2f7e88f700] DEBUG - MDE: Selected protocol dash; container: mp4
Nov 18, 2019 22:11:41.616 [0x7f2f7e88f700] DEBUG - MDE: analyzing media item 35
Nov 18, 2019 22:11:41.616 [0x7f2f7e88f700] DEBUG - MDE: Argo (2012): Direct Play is disabled
Nov 18, 2019 22:11:41.616 [0x7f2f7e88f700] DEBUG - MDE: Argo (2012): media must be transcoded in order to use the dash protocol
Nov 18, 2019 22:11:41.617 [0x7f2f7e88f700] DEBUG - MDE: Argo (2012): no direct play video profile exists for http/mkv/h264
Nov 18, 2019 22:11:41.617 [0x7f2f7e88f700] DEBUG - MDE: Argo (2012): no direct play video profile exists for http/mkv/h264/dca
Nov 18, 2019 22:11:41.617 [0x7f2f7e88f700] DEBUG - MDE: Argo (2012): no direct play video profile exists for http/mkv/h264/ac3
Nov 18, 2019 22:11:41.617 [0x7f2f7e88f700] DEBUG - MDE: Cannot direct stream audio stream due to codec dca when profile only allows aac
Nov 18, 2019 22:11:41.617 [0x7f2f7e88f700] DEBUG - MDE: Argo (2012): selected media 0 / 35
Nov 18, 2019 22:11:41.617 [0x7f2f7e88f700] DEBUG - Streaming Resource: Added session 0x7f2fbc07b140:5au2ex1e5rvft14ll8vce738
Nov 18, 2019 22:11:41.617 [0x7f2f7e88f700] DEBUG - Streaming Resource: Reached Decision id=40 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=35 part=(id=35 decision=transcode container=mp4 protocol=dash streams=(Video=(id=841 decision=copy width=1920 height=1080) Audio=(id=842 decision=transcode bitrate=256 encoder=aac channels=2 rate=48000))))
Nov 18, 2019 22:11:41.620 [0x7f2fc0e3a700] DEBUG - Completed: [192.168.1.187:60033] 200 GET /video/:/transcode/universal/decision?hasMDE=1&path=%2Flibrary%2Fmetadata%2F40&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&addDebugOverlay=0&autoAdjustQuality=1&directStreamAudio=1&mediaBufferSize=102400&session=k1mas0j142palypur0q81pzc&subtitles=burn&Accept-Language=en (9 live) TLS GZIP 41ms 5311 bytes (pipelined: 17)
Nov 18, 2019 22:11:41.628 [0x7f2fc0b4c700] DEBUG - Auth: authenticated user 1 as trelane0@hotmail.com
Nov 18, 2019 22:11:41.628 [0x7f2fb8a13700] DEBUG - Request: [192.168.1.187:60033 (Subnet)] GET /status/sessions (9 live) TLS GZIP Signed-in Token (trelane0@hotmail.com)
Nov 18, 2019 22:11:41.628 [0x7f2fb8a13700] DEBUG - [Now] Adding 1 sessions.
Nov 18, 2019 22:11:41.630 [0x7f2fc0e3a700] DEBUG - Completed: [192.168.1.187:60033] 200 GET /status/sessions (9 live) TLS GZIP 2ms 5407 bytes (pipelined: 18)
Nov 18, 2019 22:11:41.632 [0x7f2fc0b4c700] DEBUG - Auth: authenticated user 1 as trelane0@hotmail.com
Nov 18, 2019 22:11:41.633 [0x7f2fb98b9700] DEBUG - Request: [192.168.1.187:60062 (Subnet)] GET /status/sessions (9 live) TLS GZIP Signed-in Token (trelane0@hotmail.com)
Nov 18, 2019 22:11:41.633 [0x7f2fb98b9700] DEBUG - [Now] Adding 1 sessions.
Nov 18, 2019 22:11:41.634 [0x7f2fc0e3a700] DEBUG - Auth: authenticated user 1 as trelane0@hotmail.com
Nov 18, 2019 22:11:41.635 [0x7f2fb8a13700] DEBUG - Request: [192.168.1.187:60033 (Subnet)] GET /playQueues/41?repeat=0&own=1&includeChapters=1&includeGeolocation=1&includeExternalMedia=1 (9 live) TLS GZIP Signed-in Token (trelane0@hotmail.com)
Nov 18, 2019 22:11:41.636 [0x7f2fb8a13700] DEBUG - PlayQueue: total generated: 1, before cursor: 0, after cursor: 0
Nov 18, 2019 22:11:41.636 [0x7f2fb8a13700] DEBUG - PlayQueue: No need to refresh, active window is operational.
Nov 18, 2019 22:11:41.636 [0x7f2fc0b4c700] DEBUG - Completed: [192.168.1.187:60062] 200 GET /status/sessions (9 live) TLS GZIP 3ms 5407 bytes (pipelined: 3)
Nov 18, 2019 22:11:41.644 [0x7f2fb8a13700] DEBUG - It took 10.000000 ms to retrieve 110 items.
Nov 18, 2019 22:11:41.644 [0x7f2fb8a13700] DEBUG - PlayQueue: Client 76kpw8mdkyl4e1r9lwnqvs5c requested ownership of play queue 41, but already had it.
Nov 18, 2019 22:11:41.646 [0x7f2fb8a13700] DEBUG - We're going to try to auto-select an audio stream for account 1.
Nov 18, 2019 22:11:41.646 [0x7f2fb8a13700] DEBUG - Selecting best audio stream for part ID 35 (autoselect: 0 language: en)
Nov 18, 2019 22:11:41.646 [0x7f2fb8a13700] DEBUG - Audio Stream: 842, Subtitle Stream: -1
Nov 18, 2019 22:11:41.648 [0x7f2fc0b4c700] DEBUG - Completed: [192.168.1.187:60033] 200 GET /playQueues/41?repeat=0&own=1&includeChapters=1&includeGeolocation=1&includeExternalMedia=1 (9 live) TLS GZIP 13ms 5610 bytes (pipelined: 19)
Nov 18, 2019 22:11:41.714 [0x7f2fb98b9700] DEBUG - Request: [192.168.1.187:60057 (Subnet)] GET /web/js/chunk-8-f56d5f4b387f0986c81c-plex-4.8.4-d12b992.js (9 live) GZIP Signed-in
Nov 18, 2019 22:11:41.715 [0x7f2fb98b9700] DEBUG - Final path: "/volume1/@appstore/Plex Media Server/Resources/Plug-ins-36236cc4c/WebClient.bundle/Contents/Resources/js/chunk-8-f56d5f4b387f0986c81c-plex-4.8.4-d12b992.js"
Nov 18, 2019 22:11:41.715 [0x7f2fb98b9700] DEBUG - Content-Length of /volume1/@appstore/Plex Media Server/Resources/Plug-ins-36236cc4c/WebClient.bundle/Contents/Resources/js/chunk-8-f56d5f4b387f0986c81c-plex-4.8.4-d12b992.js is 277265 (of total: 277265).
Nov 18, 2019 22:11:41.715 [0x7f2fb8a13700] DEBUG - Request: [192.168.1.187:60078 (Subnet)] GET /web/js/chunk-6-60826b166e6abb12e6e5-plex-4.8.4-d12b992.js (10 live) GZIP Signed-in
Nov 18, 2019 22:11:41.715 [0x7f2fb8a13700] DEBUG - Final path: "/volume1/@appstore/Plex Media Server/Resources/Plug-ins-36236cc4c/WebClient.bundle/Contents/Resources/js/chunk-6-60826b166e6abb12e6e5-plex-4.8.4-d12b992.js"
Nov 18, 2019 22:11:41.716 [0x7f2fb8a13700] DEBUG - Content-Length of /volume1/@appstore/Plex Media Server/Resources/Plug-ins-36236cc4c/WebClient.bundle/Contents/Resources/js/chunk-6-60826b166e6abb12e6e5-plex-4.8.4-d12b992.js is 7248 (of total: 7248).
Nov 18, 2019 22:11:41.716 [0x7f2fc0b4c700] DEBUG - Completed: [192.168.1.187:60078] 200 GET /web/js/chunk-6-60826b166e6abb12e6e5-plex-4.8.4-d12b992.js (10 live) GZIP 1ms 7248 bytes (pipelined: 1)
Nov 18, 2019 22:11:41.725 [0x7f2fc0b4c700] DEBUG - Completed: [192.168.1.187:60057] 200 GET /web/js/chunk-8-f56d5f4b387f0986c81c-plex-4.8.4-d12b992.js (10 live) GZIP 10ms 277265 bytes (pipelined: 6)
Nov 18, 2019 22:11:41.836 [0x7f2fc0e3a700] DEBUG - Auth: authenticated user 1 as trelane0@hotmail.com
Nov 18, 2019 22:11:41.836 [0x7f2f7e88f700] DEBUG - Request: [192.168.1.187:60033 (Subnet)] GET /video/:/transcode/universal/start.mpd?hasMDE=1&path=%2Flibrary%2Fmetadata%2F40&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&addDebugOverlay=0&autoAdjustQuality=1&directStreamAudio=1&mediaBufferSize=102400&session=k1mas0j142palypur0q81pzc&subtitles=burn&Accept-Language=en (10 live) TLS GZIP Signed-in Token (trelane0@hotmail.com)
Nov 18, 2019 22:11:41.836 [0x7f2f7e88f700] DEBUG - Found session GUID of k1mas0j142palypur0q81pzc in session start.
Nov 18, 2019 22:11:41.837 [0x7f2f7e88f700] DEBUG - TranscodeUniversalRequest: using augmented profile Web
Nov 18, 2019 22:11:41.837 [0x7f2f7e88f700] DEBUG - Downloading document http://127.0.0.1:32400/library/metadata/40?checkFiles=1&includeBandwidths=1&offset=-1&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=5au2ex1e5rvft14ll8vce738
Nov 18, 2019 22:11:41.838 [0x7f2f7e88f700] DEBUG - Auth: authenticated user 1 as trelane0@hotmail.com
Nov 18, 2019 22:11:41.844 [0x7f2f7e88f700] DEBUG - It took 10.000000 ms to retrieve 110 items.
Nov 18, 2019 22:11:41.847 [0x7f2f7e88f700] DEBUG - We're going to try to auto-select an audio stream for account 1.
Nov 18, 2019 22:11:41.847 [0x7f2f7e88f700] DEBUG - Selecting best audio stream for part ID 35 (autoselect: 0 language: en)
Nov 18, 2019 22:11:41.847 [0x7f2f7e88f700] DEBUG - Audio Stream: 842, Subtitle Stream: -1
Nov 18, 2019 22:11:41.849 [0x7f2f7e88f700] DEBUG - Found session GUID of k1mas0j142palypur0q81pzc in session start.
Nov 18, 2019 22:11:41.849 [0x7f2f7e88f700] DEBUG - Cleaning directory for session k1mas0j142palypur0q81pzc ()
Nov 18, 2019 22:11:41.850 [0x7f2f7e88f700] DEBUG - Starting a transcode session k1mas0j142palypur0q81pzc at offset -1.0 (state=3)
Nov 18, 2019 22:11:41.850 [0x7f2f7e88f700] DEBUG - TPU: hardware transcoding: enabled, but no hardware decode accelerator found
Nov 18, 2019 22:11:41.850 [0x7f2f7e88f700] DEBUG - [Universal] Using local file path instead of URL: /volume1/Media/Movies/Films/Argo/Argo_t00.mkv
Nov 18, 2019 22:11:41.851 [0x7f2f7e88f700] DEBUG - TPU: hardware transcoding: final decoder: , final encoder:
Nov 18, 2019 22:11:41.851 [0x7f2f7e88f700] DEBUG - Job running: EAE_ROOT='/volume1/Plex/tmp_transcoding/pms-f339b9bb-e6da-4acb-b417-34ebb00fc26c/EasyAudioEncoder' FFMPEG_EXTERNAL_LIBS='/volume1/Plex/Library/Application\ Support/Plex\ Media\ Server/Codecs/395e79c-2735-linux-x86_64/' XDG_CACHE_HOME='/volume1/Plex/Library/Application Support/Plex Media Server/Cache' XDG_DATA_HOME='/volume1/@appstore/Plex Media Server/Resources' X_PLEX_TOKEN='xxxxxxxxxxxxxxxxxxxx' '/volume1/@appstore/Plex Media Server/Plex Transcoder' '-codec:0' 'h264' '-codec:1' 'dca' '-ss' '0' '-noaccurate_seek' '-analyzeduration' '20000000' '-probesize' '20000000' '-i' '/volume1/Media/Movies/Films/Argo/Argo_t00.mkv' '-filter_complex' '[0:1] aresample=async=1:ocl='\''stereo'\'':osr=48000[0]' '-map' '0:0' '-metadata:s:0' 'language=eng' '-codec:0' 'copy' '-map' '[0]' '-metadata:s:1' 'language=eng' '-codec:1' 'aac' '-b:1' '256k' '-f' 'dash' '-seg_duration' '5' '-init_seg_name' 'init-stream$RepresentationID$.m4s' '-media_seg_name' 'chunk-stream$RepresentationID$-$Number%05d$.m4s' '-window_size' '5' '-delete_removed' 'false' '-skip_to_segment' '1' '-time_delta' '0.0625' '-manifest_name' 'http://127.0.0.1:32400/video/:/transcode/session/k1mas0j142palypur0q81pzc/d572b11d-ce83-4ee2-97dc-0f1cc2fef82c/manifest' '-avoid_negative_ts' 'disabled' '-map_metadata' '-1' '-map_chapters' '-1' 'dash' '-start_at_zero' '-copyts' '-vsync' 'cfr' '-y' '-nostats' '-loglevel' 'quiet' '-loglevel_plex' 'error' '-progressurl' 'http://127.0.0.1:32400/video/:/transcode/session/k1mas0j142palypur0q81pzc/d572b11d-ce83-4ee2-97dc-0f1cc2fef82c/progress'
Nov 18, 2019 22:11:41.852 [0x7f2f7e88f700] DEBUG - Jobs: Starting child process with pid 5788
Nov 18, 2019 22:11:41.856 [0x7f2fb8a13700] DEBUG - Request: [127.0.0.1:55866 (Loopback)] PUT /video/:/transcode/session/k1mas0j142palypur0q81pzc/d572b11d-ce83-4ee2-97dc-0f1cc2fef82c/progress?status=startup (11 live) Signed-in Token (trelane0@hotmail.com) (range: bytes=0-)
For the repro, the playback is happening in Chrome (Version 78.0.3904.97 (Official Build) (64-bit)) on a desktop PC that’s also on my network.
Docker? VM ?
The J3355 CPU has the QSV ASIC but it’s not being detected. VMs and Containers are the most common abstraction which obscures it from being seen.
I am not running the browser in a docker container or VM. The only thing I can think of is I may have a Hyper-v Ethernet adapter in windows despite not running or using a VM. Could the hyper-v Ethernet adapter have impact here?
Can we clarify please?
Hyper-V should not be involved with anything on the Synology Server aspect.
Would you please clarify your topology?
So my NAS just has PMS running; no hyper-V. On my win 10 desktop, I’m just running Plex client in a browser; no VMs are running.
Hyper-V comes into the picture since, on windows client, when I go to settings -> Ethernet -> change adapter options, I see multiple items listed. Some are Hyper-V Virtual Ethernet adapters.
Ah, so you are seeing the virtual adapters for your Hyper-V guests.
In this context, they aren’t worth mentioning. They only add confusion.
I would like you to get the PuTTy app so you can log into the Synology.
  1. Synology - Control Panel - Terminal & SNMP - Enable SSH
  2. Using PuTTy, sign into your Synology and arrive at the command line prompt
  3. type: ls -la /dev/dri
  4. We should see something like this:
[chuck@lizum /.207]$ ls -la /dev/dri
total 0
drwxr-xr-x.  3 root root        140 Nov 19 16:02 ./
drwxr-xr-x. 21 root root       4560 Nov 19 16:03 ../
drwxr-xr-x.  2 root root        120 Nov 19 16:02 by-path/
crw-rw----+  1 root render 226,   0 Nov 19 16:02 card0
crw-rw----.  1 root render 226, 128 Nov 19 16:02 renderD128
[chuck@lizum /.208]$
I am interested in verifying renderD128 exists.
Here’s what I see:
drwxr-xr-x  2 root root       100 Nov 16 12:30 .
drwxr-xr-x 12 root root     18640 Nov 16 12:30 ..
crw-rw----  1 root video 226,   0 Nov 16 12:32 card0
crw-rw----  1 root video 226,  64 Nov 16 12:32 controlD64
crw-rw----  1 root video 226, 128 Nov 16 12:32 renderD128
Please pick a video file which is H.264 , without subtitles, please.
Please play the file,
Let it play for 20 seconds.
Stop playback.
Wait 30 second for logs to settle.
Settings - Settings - Troubleshooting - Download Logs.
Attach that zip.
9:08:55 - playback finished
9:09:30 - logs downloaded
Plex Media Server Logs_2019-11-19_21-09-44.zip (4.0 MB)
This is bizarre. The entries are there but it’s not being seen.
Let’s get harsh with it:
  1. SSH into it again
  2. sudo -su root
  3. cd /dev/dri
  4. chmod 666 *
Now retest.
If this works, I know where the problem is.
Do I need to restart Plex?
Just tried it but problem still occurred. I did restart Plex in PMS. Still testing with Argo as the film.
Playback finished 9:32:53
Logs: Plex Media Server Logs_2019-11-19_21-33-43.zip (3.9 MB)
BTW, is it an issue that in your ls -la output, the renderD128 entry is tied to the render group, but it’s tied to the video group for me?
This is just messed up.
  1. Uninstall the package.
  2. Restart DSM.
  3. Install PMS.
  4. Try it again.
I ask this because when the installer runs, I setup the video group right before finishing the installation.
Tried those steps but still repro’ing the problem. Playback was around 9:52.
Logs: Plex Media Server Logs_2019-11-19_21-53-54.zip (2.4 MB)
Here’s the ls -la output again:
drwxr-xr-x 2 root root 100 Nov 19 21:49 .
drwxr-xr-x 12 root root 18640 Nov 19 21:49 …
crw-rw---- 1 root video 226, 0 Nov 19 21:52 card0
crw-rw---- 1 root video 226, 64 Nov 19 21:52 controlD64
crw-rw---- 1 root video 226, 128 Nov 19 21:52 renderD128
The spk I’m using is PlexMediaServer-1.18.2.2029-36236cc4c-x86_64
