Why those subtitles will not appear
Hello, i read on Local subtitle , and i add to put Local Server to be my first choice for library Film,
When i edit the film It shown unknown subtitle in choice of subtitle, i select this one, but its doesnt appear in the movie. Why ?
I add those picture so you can see there is subtitles attached to this file and it wont appear![]
Last report on that subject
It appear sometime but still , i have a bug sometime it shoes sometime it wont
@“afauteux1959@gmail.com”
Be sure to let everyone know you have a Leelbox device. Might even help to edit your title to include this information.
For the helpers out there. Here is some history & more screen shots on the issue.
It doesnt work with the windows apli. but it works on my androird apli for my box from leelbox, i dont undestand
Oh, that’s great. You got the Leelbox to work.
When you say windows apli are you talking about PlexWeb(that opens in a internet browser)?
Yes the appli. windows i start plex like that see picture
Ahh… We here call that PlexWeb.
To be honest, it looks like you are using an updated version of PlexWeb that I don’t have. I guess the updated versions allow you to select the size of subtitle. That’s kinda cool. Anyhow, from the above pictures it seems the subtitles should be playing. I can’t see why they are not being displayed.
Yes its the plexweb but it doesnt work for the subtitle it is showing in the choice menu but it doesnt appear
That I can’t help you with. I do not know PlexWeb all that much when it come to playing media.
You might try a different web browser such as Firefox or similar.
Use Plex Media Player - top of the forum/downloads/get an app.
Plexweb works in the browser - subject to all the shortcomings of trying to watch stuff in your browser.
PMP doesn’t.
Simple as that.
Still - if the subtitles aren’t there to select - you’re not doing something right.
Log Files:
https://support.plex.tv/articles/200250417-plex-media-server-log-files/
Drag zip file to message window and drop it.
Do let us know the name of the show/movie you’re having a problem with… my crystal ball is broken.
Here is the log files and the database, you can investigate. The problem is the subtitle in every film are not appearing on my screen but it appeared as the selection choice. I cant add the files logfiles.rar its tell me the files fail to upload
Needs to be the zip file - and don’t need your database - or want it.
Just the logs - and the name of an item (or three) that’s misbehaving.
I put the log files in zip format
You are completely - 100% - non-compliant in your Media Preparation:
https://support.plex.tv/articles/categories/media-preparation/
https://support.plex.tv/articles/200381023-naming-movie-files/
https://support.plex.tv/articles/200220687-naming-series-season-based-tv-shows/
You are using a downloads folder as a Plex Library - no can do.
You are completely - 100% - non-compliant in adding subtitles:
https://support.plex.tv/articles/200471133-adding-local-subtitles-to-your-media/
The subtitle file must be named EXACTLY LIKE THE MEDIA FILE - except, of course for ‘eng.srt’.
The subtitle file must be placed next to the media file - in the same folder.
Apr 18, 2018 13:29:57.726 [11236] DEBUG - Skipping over directory 'Saturday.Night.Live.S43E13.WEBRip.x264-ION10\Subs', as nothing has changed; removing 0 media items from map.
Apr 18, 2018 13:29:57.729 [11236] DEBUG -     * Scanning directory C:\Users\André\Tracing\Downloads\film\Saturday.Night.Live.S42E06.Dave.Chappelle.HDTV.x264-CROOKS[ettv] (parent: yes)
Apr 18, 2018 13:29:57.732 [11236] DEBUG - Adding file for scanner: "C:\Users\André\Tracing\Downloads\film\Saturday.Night.Live.S42E06.Dave.Chappelle.HDTV.x264-CROOKS[ettv]\Torrent-Downloaded-from-ExtraTorrent.cc.txt"
Apr 18, 2018 13:29:57.734 [11236] DEBUG - Skipping over directory 'Saturday.Night.Live.S42E06.Dave.Chappelle.HDTV.x264-CROOKS[ettv]', as nothing has changed; removing 0 media items from map.
Apr 18, 2018 13:29:57.737 [11236] DEBUG -     * Scanning directory C:\Users\André\Tracing\Downloads\film\In.The.Fade.2017.GERMAN.WEB-DL.x264-FGT (parent: yes)
Apr 18, 2018 13:29:57.739 [11236] DEBUG - Adding file for scanner: "C:\Users\André\Tracing\Downloads\film\In.The.Fade.2017.GERMAN.WEB-DL.x264-FGT\English.srt"
Apr 18, 2018 13:29:57.740 [11236] DEBUG - Adding file for scanner: "C:\Users\André\Tracing\Downloads\film\In.The.Fade.2017.GERMAN.WEB-DL.x264-FGT\In.The.Fade.2017.GERMAN.WEB-DL.x264-FGT.mp4"
Should be…
Movie Library Type:
Z:/Movies/ <— Example. Name not important. Folder Important. NOT a Downloads Folder. MUST be a Movie Library Type.
…In The Fade (2017)/
…In The Fade (2017).mp4
…In The Fade (2017).eng.srt
TV Show Library Type:
Z:/TV Shows <— Example. Name not important. Folder Important. NOT a Downloads Folder. MUST be a TV Show Library Type.
… Saturday Night Live/
…Season 42/
…Saturday Night Live - S42E06 - Dave Chappelle, A Tribe Called Quest.mp4
…Saturday Night Live - S42E06 - Dave Chappelle, A Tribe Called Quest.eng.srt
or
…Saturday Night Live - S42E06.mp4
…Saturday Night Live - S42E06.eng.srt
The episode name is optional.
You are also using MP4 Files:
FileBot (link in my signature) can handle that naming and structuring for you automatically or manually in seconds.
What FileBot can’t do is remove possible embedded metadata in the Title Field of MP4/M4V files. Plex will read this info and prefer it over a perfect file name/structure, but you can combat that situation by moving Local Media Assets to the bottom of every agent list you can find. All tabs in TV Shows and Movies here:
https://support.plex.tv/hc/en-us/articles/200241558-Agents
Just drag LMA to the bottom of the list and drop it. If you do have embedded metadata this will cure the issue, if you don’t it won’t matter. LMA will do what it has to from the bottom.
Local Media Assets MUST be enabled for subtitles to work. Local Media Assets MUST be moved to the bottom of each list. Moved, Not Disabled.
Renaming/restructuring is best performed OUTSIDE the library and you may need to write a new bundle for the show or movie so The Plex Dance® was invented:
The Plex Dance®:
  1. remove show/movie from library
  2. rescan library files
  3. empty trash
  4. clean bundles
    https://support.plex.tv/hc/en-us/articles/200392106-Library-Actions <— scan library files, empty trash, clean bundles
  5. bring names and structures into compliance/Move LMA/etc
  6. replace corrected show/movie into library
  7. rescan library files
All Steps. In Order. No Shortcuts.
Man this is a lot of info you gave me , i will study each step you told meto do, after that i will be an expert in subtitle Ha ! Ha! Again i thank you for your support
Man this is a lot of info you gave me , i will study each step you told meto do, after that i will be an expert in subtitle Ha ! Ha! Again i thank you for your support\
I did what you said could you confirm me, i did get somesubtitle choice in french and it still doesnt appear What ?
I’ll look in a minute/hour/decade…
In the meantime the second shift can step in…
B)
Hi, here the last log files after i did all the things you ask me if you could verify it
Hello, the subtitle that are on my computer works it worth the effort i put on that and i thank you for the advise you told me, but the subtitle that come from exterior of my pc like the agent setup they are not working. Could tell me some parameters to set , my setup for plex will be great
… and right about here, we’re over my head.
More Advanced help is required 'cause we’re working with poorly named files and structures, not to mention a plugin that may have gone rogue.
Apr 19, 2018 23:02:58.212 [9248] DEBUG - Adding subdirectory for scanner: "C:\Users\André\Tracing\Downloads\Media\Movies\The.Death.of.Stalin.2017.WEB-DL.x264-FGT"
Apr 19, 2018 23:02:58.212 [9248] DEBUG - Adding subdirectory for scanner: "C:\Users\André\Tracing\Downloads\Media\Movies\The.Disaster.Artist.2017.WEBRip.x264-FGT"
Apr 19, 2018 23:02:58.216 [9248] DEBUG - Skipping over directory '', as nothing has changed; removing 0 media items from map.
Apr 19, 2018 23:02:58.250 [9248] DEBUG -     * Scanning directory C:\Users\André\Tracing\Downloads\Media\Movies\The.Death.of.Stalin.2017.WEB-DL.x264-FGT (parent: yes)
Apr 19, 2018 23:02:58.251 [9248] DEBUG - Adding file for scanner: "C:\Users\André\Tracing\Downloads\Media\Movies\The.Death.of.Stalin.2017.WEB-DL.x264-FGT\The Death of Stalin.(2017).fr.srt"
Apr 19, 2018 23:02:58.252 [9248] DEBUG - Adding file for scanner: "C:\Users\André\Tracing\Downloads\Media\Movies\The.Death.of.Stalin.2017.WEB-DL.x264-FGT\The Death of Stalin.(2017).mp4"
Apr 19, 2018 23:02:58.260 [9248] DEBUG - Skipping over directory 'The.Death.of.Stalin.2017.WEB-DL.x264-FGT', as nothing has changed; removing 1 media items from map.
Right, so I don’t know what that means, but I can tell you if you don’t name the files right and also name the .srt properly - you won’t get any subs.
@OttoKerner may have other important messages…
