Why won't my Onkyo AV receiver play content via DLNA?
The reeceiver “sees” the DLNA Plex server but the content “cannot play.” I can scroll through the folders and files but playback doesn’t work. The DLNA feature is enabled . Is there a fix or something I’ve missed?
What content are you trying to play? And what model receiver do you have?
Music files cleaned up with Music Brainz Picard
It’s a TRX 809 and streams fine with my Win 10 built in share/server system
Sorry, see the 2 posts above
Download the server logs and post them here, we can take a look and see if there are any DLNA errors.
Here ya go:
2017-01-07 13:30:39,641 (2620) : INFO (core:349) - Starting framework core - Version: 2.6.3, Build: b38628e (Thu Dec 15 13:37:00 UTC 2016)
2017-01-07 13:30:39,641 (2620) : DEBUG (core:361) - Using the elevated policy
2017-01-07 13:30:39,641 (2620) : DEBUG (core:450) - Starting runtime component.
2017-01-07 13:30:39,641 (2620) : DEBUG (core:450) - Starting caching component.
2017-01-07 13:30:39,642 (2620) : DEBUG (core:450) - Starting data component.
2017-01-07 13:30:39,642 (2620) : DEBUG (core:450) - Starting networking component.
2017-01-07 13:30:39,642 (2620) : DEBUG (networking:284) - Loaded HTTP cookies
2017-01-07 13:30:39,648 (2620) : DEBUG (caching:108) - No info file found, trashing the cache folder
2017-01-07 13:30:39,655 (2620) : DEBUG (networking:452) - Setting the default network timeout to 20.0
2017-01-07 13:30:39,657 (2620) : DEBUG (core:450) - Starting localization component.
2017-01-07 13:30:39,657 (2620) : INFO (localization:409) - Setting the default locale to en-us
2017-01-07 13:30:39,657 (2620) : DEBUG (core:450) - Starting messaging component.
2017-01-07 13:30:39,657 (2620) : DEBUG (core:450) - Starting debugging component.
2017-01-07 13:30:39,657 (2620) : DEBUG (core:450) - Starting services component.
2017-01-07 13:30:39,657 (2620) : DEBUG (core:450) - Starting myplex component.
2017-01-07 13:30:39,657 (1248) : DEBUG (networking:166) - Requesting ‘http://127.0.0.1:32400/system/messaging/clear_events/com.plexapp.agents.fanarttv
2017-01-07 13:30:39,657 (2620) : DEBUG (core:450) - Starting notifications component.
2017-01-07 13:30:39,753 (2620) : DEBUG (accessor:68) - Creating a new model access point for provider com.plexapp.agents.fanarttv in namespace ‘metadata’
2017-01-07 13:30:39,757 (2620) : DEBUG (networking:166) - Requesting ‘http://127.0.0.1:32400/:/plugins/com.plexapp.system/resourceHashes
2017-01-07 13:30:39,877 (2620) : DEBUG (runtime:1117) - Created a thread named ‘load_all_services’
2017-01-07 13:30:39,877 (2298) : DEBUG (services:265) - Plug-in is not daemonized - loading services from system
2017-01-07 13:30:39,878 (2620) : DEBUG (runtime:1117) - Created a thread named ‘get_server_info’
2017-01-07 13:30:39,880 (2620) : DEBUG (core:150) - Finished starting framework core
2017-01-07 13:30:39,880 (2620) : DEBUG (core:560) - Loading plug-in code
2017-01-07 13:30:39,881 (195c) : DEBUG (networking:166) - Requesting ‘http://127.0.0.1:32400
2017-01-07 13:30:39,881 (2298) : DEBUG (networking:166) - Requesting ‘http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X0J1bmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_
2017-01-07 13:30:39,900 (195c) : DEBUG (core:538) - Machine identifier is 50b2ec5554ae1e8c3544c90021697f485a201390
2017-01-07 13:30:39,900 (195c) : DEBUG (core:539) - Server version is 1.3.3.3148-b38628e
2017-01-07 13:30:39,971 (2620) : DEBUG (core:566) - Finished loading plug-in code
2017-01-07 13:30:39,971 (2620) : DEBUG (messaging:69) - Exposing function AlbumPosters for remote access
2017-01-07 13:30:39,973 (2620) : DEBUG (agentkit:1104) - Creating new agent class called FanartTVAgent
2017-01-07 13:30:39,973 (2620) : DEBUG (agentkit:922) - Updating agent information: [{‘media_types’: [‘Movie’], ‘accepts_from’: None, ‘fallback_agent’: None, ‘contributes_to’: [‘com.plexapp.agents.imdb’, ‘com.plexapp.agents.themoviedb’], ‘languages’: [‘xn’], ‘persist_stored_files’: True, ‘version’: 0, ‘primary_provider’: False, ‘prefs’: True, ‘name’: ‘Fanart.tv’}]
2017-01-07 13:30:40,035 (2620) : DEBUG (networking:166) - Requesting ‘http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X0FnZW50U2VydmljZTpVcGRhdGVJbmZv/Y2VyZWFsMQoxCmxpc3QKMApyMAo_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_
2017-01-07 13:30:40,049 (2620) : DEBUG (agentkit:1104) - Creating new agent class called FanartTVAgent
2017-01-07 13:30:40,049 (2620) : DEBUG (agentkit:922) - Updating agent information: [{‘media_types’: [‘Movie’], ‘accepts_from’: None, ‘fallback_agent’: None, ‘contributes_to’: [‘com.plexapp.agents.imdb’, ‘com.plexapp.agents.themoviedb’], ‘languages’: [‘xn’], ‘persist_stored_files’: True, ‘version’: 0, ‘primary_provider’: False, ‘prefs’: True, ‘name’: ‘Fanart.tv’}, {‘media_types’: [‘TV_Show’], ‘accepts_from’: None, ‘fallback_agent’: None, ‘contributes_to’: [‘com.plexapp.agents.thetvdb’, ‘com.plexapp.agents.themoviedb’], ‘languages’: [‘xn’], ‘persist_stored_files’: True, ‘version’: 0, ‘primary_provider’: False, ‘prefs’: True, ‘name’: ‘Fanart.tv’}]
2017-01-07 13:30:40,052 (2620) : DEBUG (networking:166) - Requesting ‘http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X0FnZW50U2VydmljZTpVcGRhdGVJbmZv/Y2VyZWFsMQoxCmxpc3QKMApyMAo_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_
2017-01-07 13:30:40,069 (2620) : DEBUG (agentkit:1104) - Creating new agent class called FanartTVAgent
2017-01-07 13:30:40,071 (2620) : DEBUG (agentkit:922) - Updating agent information: [{‘media_types’: [‘Movie’], ‘accepts_from’: None, ‘fallback_agent’: None, ‘contributes_to’: [‘com.plexapp.agents.imdb’, ‘com.plexapp.agents.themoviedb’], ‘languages’: [‘xn’], ‘persist_stored_files’: True, ‘version’: 0, ‘primary_provider’: False, ‘prefs’: True, ‘name’: ‘Fanart.tv’}, {‘media_types’: [‘TV_Show’], ‘accepts_from’: None, ‘fallback_agent’: None, ‘contributes_to’: [‘com.plexapp.agents.thetvdb’, ‘com.plexapp.agents.themoviedb’], ‘languages’: [‘xn’], ‘persist_stored_files’: True, ‘version’: 0, ‘primary_provider’: False, ‘prefs’: True, ‘name’: ‘Fanart.tv’}, {‘media_types’: [‘Artist’], ‘accepts_from’: None, ‘fallback_agent’: None, ‘contributes_to’: [‘com.plexapp.agents.lastfm’], ‘languages’: [‘xn’], ‘persist_stored_files’: True, ‘version’: 0, ‘primary_provider’: False, ‘prefs’: True, ‘name’: ‘Fanart.tv’}]
2017-01-07 13:30:40,072 (2620) : DEBUG (networking:166) - Requesting ‘http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X0FnZW50U2VydmljZTpVcGRhdGVJbmZv/Y2VyZWFsMQoxCmxpc3QKMApyMAo_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
2017-01-07 13:30:40,094 (2620) : DEBUG (agentkit:1104) - Creating new agent class called FanartTVAgent
2017-01-07 13:30:40,095 (2620) : DEBUG (agentkit:922) - Updating agent information: [{‘media_types’: [‘Movie’], ‘accepts_from’: None, ‘fallback_agent’: None, ‘contributes_to’: [‘com.plexapp.agents.imdb’, ‘com.plexapp.agents.themoviedb’], ‘languages’: [‘xn’], ‘persist_stored_files’: True, ‘version’: 0, ‘primary_provider’: False, ‘prefs’: True, ‘name’: ‘Fanart.tv’}, {‘media_types’: [‘TV_Show’], ‘accepts_from’: None, ‘fallback_agent’: None, ‘contributes_to’: [‘com.plexapp.agents.thetvdb’, ‘com.plexapp.agents.themoviedb’], ‘languages’: [‘xn’], ‘persist_stored_files’: True, ‘version’: 0, ‘primary_provider’: False, ‘prefs’: True, ‘name’: ‘Fanart.tv’}, {‘media_types’: [‘Artist’], ‘accepts_from’: None, ‘fallback_agent’: None, ‘contributes_to’: [‘com.plexapp.agents.lastfm’], ‘languages’: [‘xn’], ‘persist_stored_files’: True, ‘version’: 0, ‘primary_provider’: False, ‘prefs’: True, ‘name’: ‘Fanart.tv’}, {‘media_types’: [‘Album’], ‘accepts_from’: None, ‘fallback_agent’: None, ‘contributes_to’: [‘com.plexapp.agents.lastfm’], ‘languages’: [‘xn’], ‘persist_stored_files’: True, ‘version’: 0, ‘primary_provider’: False, ‘prefs’: True, ‘name’: ‘Fanart.tv’}]
2017-01-07 13:30:40,098 (2620) : DEBUG (networking:166) - Requesting ‘http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X0FnZW50U2VydmljZTpVcGRhdGVJbmZv/Y2VyZWFsMQoxCmxpc3QKMApyMAo_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
2017-01-07 13:30:40,109 (2620) : INFO (core:611) - Started plug-in
2017-01-07 13:30:40,109 (2620) : DEBUG (socketinterface:160) - Starting socket server
2017-01-07 13:30:40,111 (2620) : DEBUG (runtime:1117) - Created a thread named ‘start’
2017-01-07 13:30:40,112 (2620) : INFO (socketinterface:184) - Socket server started on port 61513
2017-01-07 13:30:40,112 (2620) : INFO (pipeinterface:25) - Entering run loop
2017-01-07 13:30:40,114 (2620) : DEBUG (runtime:717) - Handling request GET /:/prefixes
2017-01-07 13:30:40,117 (2620) : DEBUG (runtime:814) - Found route matching /:/prefixes
2017-01-07 13:30:40,118 (2620) : DEBUG (runtime:924) - Response: [200] MediaContainer, 152 bytes
2017-01-07 13:30:40,125 (2298) : DEBUG (services:362) - Loaded services
2017-01-07 13:30:40,128 (640) : DEBUG (services:438) - No shared code to load
Check if downgrading to 1.1.4 fixes it. If so, you may be impacted by another bug we’re tracking.
Was this issue resolved? I’m having the same problem with my new TX-RZ820.
I am also interested in hearing about Onkyo micro hifi like CS-N575 used as a dlna client to a plex server to play music.
Onkyo wrote:
“The CS-N575 does support DLNA from a PC or NAS device but we have not tested it with Plex so I cannot guarantee it will work/”
Thnak you
-Francois
i know this is an old post, i just got a TX-RZ720, and i had the same problem. First, renaming the Onkyo’s “friendly name” to anything that doesn’t have a dash or similar character and no spaces (TXRZ720) help it show up on my network… second, i have to periodically turn DHCP (in the receivers settings) from enable, to disable, to enable again to see my plex server when it doesn’t show up. hope that helps
