I’m running into an issue with Plex of late that seems strange to me. Some TV episodes won’t play on a remote Plex client, but the same episode plays fine with the same client connected to my WiFi network. After a friend with iPad/iOS and Roku players indicated the episodes wouldn’t play, I’ve been able to duplicate the issue on those same episodes with my Android phone. At the same time, other episodes play without issue when I’m not connected to WiFi.
I’m running PMS v1.10.1.4602 as a plugin on my unRAID 6.4.1 server. My main player is PMP 2.4.1.787-54a020cd for WIndows 10. My Android is running Plex 6.13.6.3452 (d5f0a62c) and unless I’m connected to my local network via WiFi, some episodes that play fine on Windows 10 just will never connect on my Android.
This started happening early in 2018, but I can’t recall the sequence of the following events that may play a factor:
- I installed a PCIE sata expansion card in my server (StarTech PEXSAT2) in addition to a 3TB WD Green HDD (disk space was in short supply!)
- I started using Sonarr in a Docker container to obtain TV episodes
- I had a power outage and my server/Plex did not shut down “nicely”. I’ve had several instances where PMP couldn’t display the On Deck dashboard; I restored an older index and that has generally been resolved
- Since the power outage, I’ve discovered that my CPU runs at 100% even when idle (I’m not certain this was the case before the outage, but I know the fan speeds are at full speed/especially noisy) ***** EDIT - could the CPU running at 100% prevent remote players from connecting and playing the episodes??
I’ve looked a bit at the Plex logs (which is attached for anyone to see/analyze) and have noticed the following entries:
: ERROR - [FFMPEG] - Cannot load libcuda.so.1
: WARN - avcodec_open2 returned -1313558101 for encoder ‘h264_nvenc’
: ERROR - [FFMPEG] - No VA display found for device: /dev/dri/renderD128.
------> (repeats a few times)
: WARN - CodecManager: EAE exited with code 13. Restarting.
: INFO - CodecManager: starting EAE at /mnt/user/Apps/tmp/pms-3aacf811-f592-4172-b8e9-7ed0fd004025/EasyAudioEncoder
: ERROR - JobManager: child process returned: 13 (Permission denied)
: ERROR - [Transcoder] [eac3_eae @ 0x14774e0] EAE timeout! EAE not running, or wrong folder? Could not read ‘/mnt/user/Apps/tmp/pms-3aacf811-f592-4172-b8e9-7ed0fd004025/EasyAudioEncoder/Convert to WAV (to 8ch or less)/1c220fdb563222cc-com-plexapp-android_25120-1-0.wav’
: ERROR - [Transcoder] [eac3_eae @ 0x14774e0] error reading output
: ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
: ERROR - [Transcoder] [eac3_eae @ 0x14774e0] EAE timeout! EAE not running, or wrong folder? Could not read ‘/mnt/user/Apps/tmp/pms-3aacf811-f592-4172-b8e9-7ed0fd004025/EasyAudioEncoder/Convert to WAV (to 8ch or less)/1c220fdb563222cc-com-plexapp-android_25120-1-1.wav’
------> (repeats a several/many times)
: WARN - Transcode runner appears to have died.
: WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (9471c186-4139-44f1-80ba-40a9365375c5, expected f5f7d33f-1e93-44bd-89c3-1de079473b63)
Nothing in there tells me anything, but I hope someone can provide some assistance as to what the issue might be.
