wifi setup ssh
i want to setup wifi with ssh, where are the files ?
thanks
Maybe to late for you but for other… as I just had the same need and as I found how to do it…
Enable connman wifi technology (if not already start)
connmanctl enable wifi
Scan for WIFI network nearby:
connmanctl scan wifi
List found WIFI network:
connmanctl services
Create the configuration file to access the network
put your configuration file in /storage/.cache/connman
create a file with the pattern .config
exemple of configure file (works but improvements possible)
[global]
Name = Livebox-8615
Description = Livebox-8615 Wifi service config file
[service_Livebox-8615]
Type = wifi
Name=Livebox-8615
Favorite=true
AutoConnect=true
Passphrase=xxxxxxxxxx
IPv4.method=dhcp
IPv6.method=off
IPv6.privacy=disabled
end of exemple of configure file
connect to WIFI network :
connmanctl services
check that the configured network get a “*A” at the begining of the line connmanctl connect wifi_xxxxxxxxx
And it works…
