Or Sling. Also some providers provide a way to get an MU3 file that will allow Emby to see and record from some feeds like Channels DVR and others provide. I do not think Plex can do that but I cold be wrong.
I also have found that the recording abilities Plex and Emby provides are harder to use than the apps for Spectrum from other sources. I use Channels or the Spectrum app to record and watch almost all live TV that I have interest in.
It is, to me, much easier to move live TV or TV functionality in general outside of my media manager. I know it is accepted that people want all functionality inside one device and one app on that device but, again for me, I think it is much easier and more intuitive to keep a fair amount of functionality separate in different apps and even in different devices.
If I were using several different remotes to control my system I “might” feel otherwise but I use a Harmony hub remote and it allows me to just press one button to switch devices. That also allows me to use Echo devices to provide voice commands for most everything I do. I have programmed macros that allow me to start and stop playback and change devices with simple voice commands. I can say “Alexa, Roku” or “Alexa Shield” or some others and my whole system switches to the device requested. I can also say things like “Alexa, play Roku” and I get the same effect as pressing “play” on the Roku.
One thing is that Alexa and my Echo devices do not seem to like my new Apple TV box that I was forced to get when I got the full Spectrum package. I have not been able to get Alexa to do more with Apple TV than just switch to it and provide basic remote functionality. But that matters very little as there is now a good Spectrum app for Roku so I use that for Spectrum.
Note Channels DVR does not have and has no plans for a Roku app. They do have an app for the Fire TV or the Shied but the Roku is by far my favorite.
To repeat what I have said I do not think that live TV functionality inside either Plex or Emby is at all good enough for regular use but the separate apps devices do work well for the most part.
I have tested Plex and Emby withe Sling, Hulu and Spectrum. The best, for me is Sling with Emby but that “best” is still well below the functionality of native apps for the service involved.
One more thing: If you are into sports you might really want to consider the native apps as there are channels that, sometimes, put something in their streams that prevent recording some shows. An example is that NBCSN broadcasts a number of Premier League matches but those feed are not even watchable or recordable. They, according to the Channels DVR forum, place something it the stream so the 3rd party tuners or streamers can neither watch or record those feeds. They are perfectly watchable and recordable in the apps on my Apple TV and my Roku TV. All other material works fine on NBCSN.
I “think” they do the same with the USA network when the league matches are broadcast on USA.
All of that is why I do not like using live TV inside of Plex or Emby while using live TV outside Plex or Emby is both easy and simple.
I know that both Plex and Emby strive to be the “Swiss army knife” of media managers but, while a knife of that sort works pretty well it is both better and more functional to use the correct tool for each situation.
For me Plex’s and Emby’s greatest use is playback and I believe the acquisition of media belongs in separate apps.
