Will Sync work like this
I am trying to take a load off the server so I am willing to set up a second machine for a couple of months until plex gets done uploading the data to my cloud service… After this is done, I should be able to “sync” it to any plex machine correct? I mean that is the reason for the sync correct?
Sync is from Server to client (Player) such as a tablet or phone with storage and can run the Plex app . It does not support server to server. That would be a ToS violation
Ok thanks for the answer.
Plex has 2 types of Sync. Cloud Sync, allows you to upload copies of your media to a Cloud Provider, when then acts like a mini server, allowing you to access that data. This is a one-way (up) transfer only. You cannot then tell another computer to reuse this data.
Mobile Sync is similar but instead of uploading to a Cloud Provider, it makes a copy onto your mobile device. Again, this is one-way.
If you mean “sync” as in a generic term, then it is possible using 3rd party programs but there is nothing in Plex itself. There also isn’t a way to “sync” the Plex database which is what tracks what media you have, watched status, etc. You would basically be running another separate PMS but using the same media.
Not sure what ToS violation you are referring to. You can use the same media on more than 1 server.
