Windows Plex player not working for HDR MKV TRUE AUDIO file
Server Version#:1.40.4.8679
Player Version#:1.98.2.208-0cf517e0
Trying to play the following file on Windows plex player. It plays the first few seconds then crashes/closes the stream.
Any ideas on how to fix it?
I have an A2000 on hand transcoding
Versuche es mal mit MPC-BE x64.
Vielleicht ist der File kaputt oder hat einen Fehler.
MPC-BE spielt meist auch defekte Files ab.
nope, no issue after I covert the original file to original and play
And it plays on mobile devices fine
Try replacing the mpv-2.dll with a newer one.
How to => HTPC Tips and Tricks - #2
Note that the latest mpv-2.dlls from mpv upstream do not work with plex, download them from my GitHub repo => Releases · mitzsch/mpv-winbuild · GitHub
