WINTV 950Q
Hello I have the Happauge WINTV 950Q is it supported for Live DVR
Thanks Puneet
I have it too, the WinTV-HVR-950q but was unable to make it work. It seems that only WinTV-HVR-955q is supported.
Not sure why the 950q is not, it works fine with Windows Media Center in Windows 7, works fine in Windows 10 with DSubler.
Thank you yes seems like it does not work I tried removing WINTV8 also since the documentation suggested that but no luck. I did see a post in the community indicating that it should work though? but have not seen a post from anyone that they got it to work
https://forums.plex.tv/discussion/289368/community-supported-tuners-list#should this link indicates it should work has anyone got the 950q to work with PLEX DVR?
950Q now works on my Windows 10 PMS, and I shared the comment here.
