WinTV dual not working in plex in docker on arch
I am trying to get my WinTV dual working inside my docker-container.
I already fulfilled the requirements of this site (kernel version: 4.4.20 and I copied the firmware on my host to /lib/firmware).
In my docker-compose I “tunneled”? /dev/dvb to /dev/dvb, and after that didn’t work, I also mounted the firmware of the WinTV into the container.
Unfortunately I still don’t have access to the device. Am I missing something?
That site is for using the WinTV in general. Have you looked over their steps for use with Plex, http://www.hauppauge.com/pages/support/support_linux.html?#tabs-5.
Thank you for the reply, I haven’t seen this site before.
I cloned the pms-docker repository and added the corresponding lines from the support page to the Dockerfile, but I still can’t see the tuner
Unfortunately, I an not familiar enough with dockers to assist. I know that the Hauppauge article was meant for Ubuntu and not Arch. There may be enough differences that it won’t work on Arch. You might want to contact Hauppauge and check with them.
