I am a huge fan of Plex, but the DVR is getting frustrating. I have followed all the instructions. I see two devices with two tuners in my server. I have removed the WinTV software to avoid the conflict others reported. Only 1 show will record at a time and any others will fail with the recording is aborted. I have purchased the supported antenna and when not recording I can watch channels with no stutter or lack of signal. I have removed the tuners and added them back in, but nothing changes. Any assistance would be appreciated.
I have the same card installed on a dell 620 server running server 2012 rd, bot turners show, I scanned channels on each one and now I have 4 turners to use.
Thanks, I have the same screen showing. I do have an update to this question. Apparently the issue is with comskip. If I don’t have it enabled the shows will record across all tuners and not just the one.
I have this same problem however I cannot get the second set of tuners to show up. When I originally setup the first tuner when I go back to add the second one it is no longer an option for me. Is there a way to add them both at the same time?
I just bought this and installed this and i am only getting 1 tuner. it does not show like the picture. I need help
