WinTV-QuadHD recognize 2 tuners not 4
Hi have Ubuntu Linux running Hauppauge WinTV-QuadHD which has 4 tuners. Plex recognizes this as 2 separate devices, with 2 tuners each, instead of 1 device with 4 tuners. This doesn’t seem to be right. I can only watch 2 live TV shows at the same time. How can I get it to recognize all 4 tuners as one device?
That’s correct. That’s just the way Hauppauge implemented the Linux driver and it is also discussed in the Plex support documents [1]. Just add both devices separately in the server DVR settings and you should be able to watch at least 4 parallel streams.
Also make sure to follow the setup instructions in the official Hauppauge Linux guide [2].
[1] https://support.plex.tv/articles/225877427-supported-dvr-tuners-and-antennas/
[2] Hauppauge Support | Running WinTV TV tuners and HD PVR 2 under Linux
I have the same tuner and same problem (only 2 of 4 recognized) but on a Windows 10 system. Can you advise?
