With initial login it always seems to use the admin account.
Always with the initial login with the device it skips the user selection. Is there aynway to prevent this?
Otherwise it makes the pin on the admin account pretty useless.
I haven’t found a way to stop this.
It doesn’t mean that the pin is useless as you need to have the account details and password to login in the first place. I do that myself and then check things are work and make any changes to the settings. When I have finished I switch users and hand the device back to the family member. The pin on the admin account then stops them from going back into the admin function.
