Are you 100% certain your username has R/W/Admin privilege for the Plex shared folder ?
I’m not certain but it doesn’t look like it does. Here is the Plex shared folder and the permissions tab. Under my username, nothing is checked in the read/write column but it does show Read/Write under Group permissions column. Would this be why I’m not able to do the zip file when I followed your instructions?
If I go to Plex folder in File Library and right-click, and properties and look, here is what I see:
My username isn’t even showing. It should be shouldn’t it? How do I get it to be? If I highlight “admin” and then edit, the Administration boxes are unchecked. Should I check those boxes? (I’m not sure what the difference is between admin and administrators in this capture below).
If I click Advanced permissions tab, I see this:
I have another question related to the Shared folder. I checked a couple of other shared folders (which are related to Hyper backup - i.e. “Plex USB SSD 500GB”) and when I click Edit and then Permissions, there is no checkbox on Plex, but it does show Admin and bubbascant with Read/Write. Should I do the “Customize” for Plex on any Hyper backup that I have created? And get Full Control on Admin and bubbascat? And how do I get full control on Admin and my username? Wouldn’t it be that by default as it was part of setting up my NAS to begin with?
I have several Plex Hyper backups and also Music folder. What I’m confused by is why some backups show Owner as “Admin” and the others as “bubbascant”? Those with bubbascant as owner are older, meaning I created the backup quite a while ago. The ones with Admin as owner are recent, as in the past week or so. Why would this be?
Further confusing me now is that I have one I created only a few days ago and it says shared folder is usbshare1. I’m assuming this is because I didn’t change the name when I set it up?
Man, I really appreciate you for making sure of how I have things set up.
I was going to delete several of the Hyper backups as it is a bit redundant as I have several Plex ones for example. I only need one probably.
Please let me know. THANKS
