Server Version#:1.16.6.1592-b9d49bdb7
Player Version#:1.2.0.875-b7362913
Basically, I know why it won’t record a program. The guide is setting the episode naming the same each week. I know that isn’t plex’s fault or Schedule Direct’s fault. So, is there any way to force plex to record a program and not check if you have it. When I was using NextPVR, it would record the program without issue using the same guide. And record it each week. Renaming and deleting the program doesn’t work. I tried all the solutions that I could find and I’m not going to re-install Plex every day to get the program. TIA
Maybe look into MCEbuddy? I use it to remove commercials (works better for me than PMS system) and to automatically convert to .mp4 and move to a different folder. I have it set to perform these tasks at 1am-4am (when I don’t think anyone will be watching the recordings) daily. Just an idea.
Well, I think I am wrong. Copied the file to somewhere else. Did a quick refresh after deleting it and the series showed up for one day. Now to automate the process. MCEBuddy? Ok I’ll check it out. Thanks.
I don’t believe it is a Plex problem. Because it is one show of many I record and I haven’t had any issues otherwise. And it was present in the OTA guide, too. Thanks
