Wrong media details shown with multiple versions
Server Version#: 1.40.0
Player Version#: 10.10 (its been that way for a looogn time though)
When watching at the media details on Android TV/Shield TV/Fire TV the shown stream details are wrong for every entry, but the first one, if multiple versions exist.
Compare the screenshot below with the Media Info.
Dateien
Medien
Duration 1:49:26
Bitrate 14534 kbps
Width 3840
Height 1920
Aspect Ratio 1.85
Video Resolution 4K
Container MKV
Video Frame Rate 24p
Video Profile main 10
Teil
Duration 1:49:26
File Five Nights at Freddy's [2023] - HD2160p (Deu 5.1&Eng 5.1).hdr.mkv
Size 11.11 GB
Container MKV
Codec HEVC
Bitrate 13638 kbps
Bit Depth 10
Chroma Location left
Chroma Subsampling 4:2:0
Coded Height 1920
Coded Width 3840
Color Primaries bt2020
Color Range tv
Color Space bt2020nc
Color Trc smpte2084
Frame Rate 23.976 fps
Height 1920
Level 5.1
Profil main 10
Ref Frames 1
Width 3840
Display Title 4K HDR10 (HEVC Main 10)
Extended Display Title 4K HDR10 (HEVC Main 10)
Codec AC3
Kanäle 6
Bitrate 448 kbps
Sprache Deutsch
Language Tag de
Audio Channel Layout 5.1(side)
Sampling Rate 48000 Hz
Display Title Deutsch (AC3 5.1)
Extended Display Title Deutsch (AC3 5.1)
Codec AC3
Kanäle 6
Bitrate 448 kbps
Sprache Englisch
Language Tag en
Display Title Englisch (AC3 5.1)
Extended Display Title Englisch (AC3 5.1)
Medien
Duration 1:49:26
Bitrate 5104 kbps
Width 1920
Height 960
Aspect Ratio 1.85
Video Resolution 1080p
Container MKV
Video Profile high
Teil
Duration 1:49:26
File Five Nights at Freddy's [2023] - HD1080p (Deu 5.1&Eng 5.1).mkv
Size 3.90 GB
Container MKV
Video Profile high
Codec H264
Bitrate 4208 kbps
Sprache Englisch
Language Tag en
Bit Depth 8
Coded Height 960
Coded Width 1920
Height 960
Level 4.0
Profil high
Ref Frames 4
Scan Type progressive
Width 1920
Display Title 1080p (H.264)
Extended Display Title 1080p (H.264)
Codec AC3
Kanäle 6
Bitrate 448 kbps
Sprache Deutsch
Language Tag de
Codec AC3
Kanäle 6
Bitrate 448 kbps
Sprache Englisch
Language Tag en
Medien
Duration 1:49:25
Bitrate 6130 kbps
Width 1874
Height 960
Aspect Ratio 1.85
Video Resolution 720p
Container MKV
Teil
Duration 1:49:25
File Five Nights at Freddys [2023] - HD1080p (Deu 5.1&Eng 5.1).hevc.mkv
Size 4.68 GB
Container MKV
Codec HEVC
Bitrate 4850 kbps
Bit Depth 10
Coded Height 960
Coded Width 1880
Color Primaries bt709
Color Range tv
Color Space bt709
Color Trc bt709
Height 960
Level 4.0
Profil main 10
Ref Frames 1
Width 1874
Display Title 720p (HEVC Main 10)
Extended Display Title 720p (HEVC Main 10)
Codec AC3
Kanäle 6
Bitrate 640 kbps
Sprache Deutsch
Language Tag de
Codec AC3
Kanäle 6
Bitrate 640 kbps
Sprache Englisch
Language Tag en
Codec PGS
Bitrate 12 kbps
Sprache Englisch
Language Tag en
Header Compression true
Titel English SDH
Display Title Englisch (PGS)
Extended Display Title English SDH (PGS)
Bump it up
