We are constantly seeing cover art and movie info. that has zero relation to many of our video files. This is happening to about 1/3 of our video files. Metadata being added automatically, and it’s all wrong metadata. How can this be turned off/stopped and fixed/removed? Thank You!
Server Version#: 4.145.1
Player Version#: 1.41.6.9685
If these are private videos, which are not listed on either IMDb or TheMovieDB, then use a library of the type “Other Videos”.
It will not attempt to “match” your files to a known movie title.
If your videos should be match-able though, sticking to the recommended folder organization and file naming guides is supposed to solve this issue largely.
https://support.plex.tv/articles/categories/your-media/
If you use mp4 files, verify that they either contain correct, or no embedded meta data.
