Thank you very much @OttoKerner ![]()
Iâm on it to edit the data on imdb and tmdb but will take 2-3 days till changes will be approved
How did you read out that data what you mentioned in your post earlier? i would like to check other series too if there are false entrys on plexs backend ![]()
I wrote a userscript that allows your to view the XML details of any media by opening up the media page, either on your server or through Discover, and pressing CTRL+I.
Thanks alot ![]()
Hi guys & gals, first post here so apologies if in wrong thread or section.
I am having a similar problem with âBeauty & The Beastâ (1987) TV show box set that keeps changing the information & linking to âBeauty & The Beastâ (2012), even though I keep using âFix Matchâ on it to change it back (it does it at random times not on every database update/scan) and also have added the actual year to the filenames of each episode & the folder name as in below
It is only this one TV series that the issue happens with & tbh getting a little annoyed having to keep changing it as the wife gets confused with which show will play as also got the other box set on my server as well - so it then merges the 2 together & even after splitting them up again & fixing the match for the older show, give it a few days and it will revert back.
Other shows which have remakes of older ones using the same name such as The Flash (1990) & The Flash (2014) donât have the problem even though they are using the exact same naming format including the year in each filename and folder.
I have tried different sources for the information to be pulled from with same results (I use PlexTV as default & using TVDB does the same)
Any help/suggestions/fixes would be greatly appreciated.
Thank you in advance.
Better to make your own post, but weâll try to work on it here.
Dunno why it keeps unmatching automatically to the wrong show however. I do find that using an ampersand (&) instead of the word (and) can lead to mixups, as some matchers are too literal and wonât match one with another. Meaning, that since the original 1987 show does NOT use an ampersand, perhaps using a title of Beauty and the Beast (1987) for the folder might prevent this issue.
Also, Plexâs naming scheme doesnât suggest using dots in filenames, and expects the year to be in parenthesis after the name. Either this, or using â&â in the title, might cause Plex to oddly ârematchâ these episodes to the more recent show.
Strange behavior, either way. If a filename/foldername change doesnât prevent this from coming undone again, it doesnât seem like proper behavior to me.
Thank you for the reply.
I have replaced the Ampersand with the word âandâ in the title. Thank the Omnipotent beings for Windows PowerToys PowerRename! All of my other files on my server are separated by periods & year not in parenthesis, and have been fine for past 4 years or so that been running a server here, but will keep that in mind if get any other similar issues in the future.
Hopefully this will resolve the issue (any of the others using ampersands in the name donât have duplicate seasons or other films of same name, so âshouldâ be ok there still).
Once again thank you for the rapid answer.
