Server Version#: 1.32.1.6999
Player Version#: ALL
Hi All,
Anyone experience issue with wrong thumbnail generation? The thumbnails are totally wrong for some media and couple of seconds wrong for the other media. This happened 2 versions before mention one
Do you mean the off set of preview thumbs? like you scrub to some position and it is not what you expect?
Yes, exactly. I found it when I watch sport game. On thumbnail I can see result, something 71-63, then go media and I see 83:71, you can assume, that these are couple of minutes difference, not 1 or 2 or 5 seconds…
I was able to identify the difference, around 2 minutes
What troubleshoot steps currently performed:
- delete all thumbnails in the library and create again- not able to fix
- restart PMS- not able to fix
- reboot Windows Server- not able to fix
- uninstall PMS and revert back 2 version- not able to fix
I have created VM with ubuntu plex installed there and add library with smb mount path to the same media- no issues with linux plex.
Can you get the server logs from something was added and preview thumbs became available that I can add to bug report.
If there is any way to create a short screenrecording or screenshot that shows the discrepancy it would be also appreciated.
I’m ready with all requested files. Where I can share them?
click on my username to message me a link from some online storage like google drive or attach them to message. (there is an 8mb limit on attachements)
