Hi fellas, i recently made a fresh install of Open Plex on my MBP (everything was working fine till then). Now, everytime i try to access WSJ (or any other hijacked app) i keep getting the same message: “WSJ not available. Try again later”.
So far i’ve tried:
Installing OpenPlex on a different MAC on the same network: same issue
Wiping partitions and installing Yosemite from scratch, then re-installing Open Plex: same issue.
How is your network designed (layout) from your aTV to your router, wifi? MBP to your router wifi? Same router, access points any gateways or network bridges, Ethernet converters, moca adapters, multiple dhcp servers? The more detailed you can be about this the better everyone can assist you. Who is your ISP? If you can ensure everything is running on the same AP ant not multiple AP/network segments it would be great. What is your mbp ip? What is your aTV ip?
My ISP is Fastweb (im from Italy) i pnly have one router and both the ATV and the mbp are linked to it via WiFi. No segments for what i know. Mbp IP is 192.168.1.86 ATV is 192.168.1.71
