Plex tuner log
May 15, 2018 10:15:28.998 [0x7fb6e1f16700] INFO - Plex Tuner Service v1.0.0.0 - unknown PC unknown - build:
May 15, 2018 10:15:29.000 [0x7fb6e1f16700] INFO - Linux version: 4.14.40-unRAID (#1 SMP PREEMPT Fri May 11 22:14:52 BST 2018), language: en-US
May 15, 2018 10:15:29.003 [0x7fb6e1f16700] INFO - Processor Intel® Core™ i3-4370 CPU @ 3.80GHz
May 15, 2018 10:15:29.011 [0x7fb6e1f16700] INFO - /usr/lib/plexmediaserver/Plex Tuner Service /usr/lib/plexmediaserver/Resources/Tuner/Private /usr/lib/plexmediaserver/Resources/Tuner/Shared 1.13.0.5023-31d3c0c65 32600 /waitmutex
May 15, 2018 10:15:28.448 [0x7fb6e7261780] INFO - * broker_t::start…
May 15, 2018 10:15:28.457 [0x7fb6e7261780] INFO - * device_manager_t::init.
May 15, 2018 10:15:28.467 [0x7fb6e7261780] INFO - * device_manager_t::init. Initialize provider manager
May 15, 2018 10:15:28.467 [0x7fb6e7261780] INFO - * device_manager_t::init. Initialize all device auxes
May 15, 2018 10:15:28.467 [0x7fb6e7261780] INFO - * dvb_device_factory_t::get_aux_list
May 15, 2018 10:15:28.468 [0x7fb6e7261780] INFO - * tvbutler_aux_t::init
May 15, 2018 10:15:28.468 [0x7fb6e7261780] INFO - * web_server_t::start. Starting web server on port 32600
May 15, 2018 10:19:34.008 [0x7fb6d8567700] INFO - * web_service_t::process_device_discovery
May 15, 2018 10:19:34.008 [0x7fb6d8567700] INFO - * device_reactor_t::get_device_list ()
May 15, 2018 10:19:34.009 [0x7fb6d8567700] INFO - * dvb_device_factory_t::get_device_list ()
May 15, 2018 10:19:36.012 [0x7fb6d8567700] INFO - * SAT2IP - server discovered: 192.168.0.101
May 15, 2018 10:19:36.013 [0x7fb6d8567700] INFO - * SAT2IP - description XML: http://192.168.0.101:9981/satip_server/desc.xml
May 15, 2018 10:19:36.016 [0x7fb6d8567700] INFO - * SAT2IP - get_frontend_num_dvbs
May 15, 2018 10:19:36.017 [0x7fb6d8567700] WARN - [E] sat2ip_streamer::open_rtsp_session. rtsp_client_.connect failed 192.168.0.101
May 15, 2018 10:19:36.017 [0x7fb6d8567700] WARN - [E] sat2ip_streamer::tune. open_rtsp_session failed
May 15, 2018 10:19:36.017 [0x7fb6d8567700] INFO - * SAT2IP - get_frontend_num: tune failed
May 15, 2018 10:19:36.017 [0x7fb6d8567700] INFO - * SAT2IP - get_frontend_num_dvbt
May 15, 2018 10:19:36.018 [0x7fb6d8567700] WARN - [E] sat2ip_streamer::open_rtsp_session. rtsp_client_.connect failed 192.168.0.101
May 15, 2018 10:19:36.018 [0x7fb6d8567700] WARN - [E] sat2ip_streamer::tune. open_rtsp_session failed
May 15, 2018 10:19:36.019 [0x7fb6d8567700] INFO - * SAT2IP - get_frontend_num: tune failed
May 15, 2018 10:19:36.424 [0x7fb6d8567700] INFO - * v4l::DeviceGetList_impl. getting v4l device list
May 15, 2018 10:19:36.424 [0x7fb6d8567700] INFO - * v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
May 15, 2018 10:19:36.426 [0x7fb6d8567700] INFO - * dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.0, Name PCTV 461, Standards 4
May 15, 2018 10:19:36.426 [0x7fb6d8567700] INFO - * onetv_factory::DeviceGetListEx >>
May 15, 2018 10:19:36.427 [0x7fb6d8567700] INFO - * onetv_factory::DeviceGetListEx. Found device 8211:600
May 15, 2018 10:19:36.427 [0x7fb6d8567700] INFO - * onetv_factory::DeviceGetListEx. Found device 2316:4096
May 15, 2018 10:19:36.427 [0x7fb6d8567700] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:3
May 15, 2018 10:19:36.427 [0x7fb6d8567700] INFO - * onetv_factory::DeviceGetListEx. Found device 1892:1281
May 15, 2018 10:19:36.427 [0x7fb6d8567700] INFO - * onetv_factory::DeviceGetListEx. Found device 32903:32776
May 15, 2018 10:19:36.427 [0x7fb6d8567700] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:2
May 15, 2018 10:19:36.428 [0x7fb6d8567700] INFO - * onetv_factory::DeviceGetListEx. Found device 32903:32768
May 15, 2018 10:19:36.428 [0x7fb6d8567700] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:2
May 15, 2018 10:19:36.428 [0x7fb6d8567700] INFO - * device_manager_t::get_device_list. Device PCTV 461, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.0, tuners 1, state 0, standards 4
May 15, 2018 10:19:36.429 [0x7fb6dac77700] INFO - * web_service_t::process_device_status
May 15, 2018 10:19:36.429 [0x7fb6dac77700] INFO - * v4l::DeviceGetList_impl. getting v4l device list
May 15, 2018 10:19:36.429 [0x7fb6dac77700] INFO - * v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
May 15, 2018 10:19:36.433 [0x7fb6dbfff700] INFO - * web_service_t::process_get_scanners
May 15, 2018 10:19:36.433 [0x7fb6dbfff700] INFO - * v4l::DeviceGetList_impl. getting v4l device list
May 15, 2018 10:19:36.433 [0x7fb6dbfff700] INFO - * v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
May 15, 2018 10:19:36.483 [0x7fb6d98ef700] INFO - * web_service_t::process_device_status
May 15, 2018 10:19:36.483 [0x7fb6d98ef700] INFO - * v4l::DeviceGetList_impl. getting v4l device list
May 15, 2018 10:19:36.483 [0x7fb6d98ef700] INFO - * v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
May 15, 2018 10:19:36.485 [0x7fb6d8567700] INFO - * web_service_t::process_get_scanners
May 15, 2018 10:19:36.485 [0x7fb6d8567700] INFO - * v4l::DeviceGetList_impl. getting v4l device list
May 15, 2018 10:19:36.485 [0x7fb6d8567700] INFO - * v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
May 15, 2018 10:19:38.597 [0x7fb6e0b8e700] INFO - * web_service_t::process_device_discovery
May 15, 2018 10:19:38.597 [0x7fb6e0b8e700] INFO - * device_reactor_t::get_device_list ()
May 15, 2018 10:19:38.597 [0x7fb6e0b8e700] INFO - * dvb_device_factory_t::get_device_list ()
May 15, 2018 10:19:40.601 [0x7fb6e0b8e700] INFO - * SAT2IP - server discovered: 192.168.0.101
May 15, 2018 10:19:40.601 [0x7fb6e0b8e700] INFO - * SAT2IP - description XML: http://192.168.0.101:9981/satip_server/desc.xml
May 15, 2018 10:19:40.604 [0x7fb6e0b8e700] INFO - * SAT2IP - get_frontend_num_dvbs
May 15, 2018 10:19:40.604 [0x7fb6e0b8e700] WARN - [E] sat2ip_streamer::open_rtsp_session. rtsp_client_.connect failed 192.168.0.101
May 15, 2018 10:19:40.604 [0x7fb6e0b8e700] WARN - [E] sat2ip_streamer::tune. open_rtsp_session failed
May 15, 2018 10:19:40.604 [0x7fb6e0b8e700] INFO - * SAT2IP - get_frontend_num: tune failed
May 15, 2018 10:19:40.604 [0x7fb6e0b8e700] INFO - * SAT2IP - get_frontend_num_dvbt
May 15, 2018 10:19:40.605 [0x7fb6e0b8e700] WARN - [E] sat2ip_streamer::open_rtsp_session. rtsp_client_.connect failed 192.168.0.101
May 15, 2018 10:19:40.605 [0x7fb6e0b8e700] WARN - [E] sat2ip_streamer::tune. open_rtsp_session failed
May 15, 2018 10:19:40.605 [0x7fb6e0b8e700] INFO - * SAT2IP - get_frontend_num: tune failed
May 15, 2018 10:19:41.009 [0x7fb6e0b8e700] INFO - * v4l::DeviceGetList_impl. getting v4l device list
May 15, 2018 10:19:41.009 [0x7fb6e0b8e700] INFO - * v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
May 15, 2018 10:19:41.014 [0x7fb6e0b8e700] INFO - * dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.0, Name PCTV 461, Standards 4
May 15, 2018 10:19:41.014 [0x7fb6e0b8e700] INFO - * onetv_factory::DeviceGetListEx >>
May 15, 2018 10:19:41.015 [0x7fb6e0b8e700] INFO - * onetv_factory::DeviceGetListEx. Found device 8211:600
May 15, 2018 10:19:41.015 [0x7fb6e0b8e700] INFO - * onetv_factory::DeviceGetListEx. Found device 2316:4096
May 15, 2018 10:19:41.015 [0x7fb6e0b8e700] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:3
May 15, 2018 10:19:41.015 [0x7fb6e0b8e700] INFO - * onetv_factory::DeviceGetListEx. Found device 1892:1281
May 15, 2018 10:19:41.015 [0x7fb6e0b8e700] INFO - * onetv_factory::DeviceGetListEx. Found device 32903:32776
May 15, 2018 10:19:41.015 [0x7fb6e0b8e700] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:2
May 15, 2018 10:19:41.015 [0x7fb6e0b8e700] INFO - * onetv_factory::DeviceGetListEx. Found device 32903:32768
May 15, 2018 10:19:41.016 [0x7fb6e0b8e700] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:2
May 15, 2018 10:19:41.016 [0x7fb6e0b8e700] INFO - * device_manager_t::get_device_list. Device PCTV 461, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.0, tuners 1, state 0, standards 4
May 15, 2018 10:19:41.019 [0x7fb6d8567700] INFO - * web_service_t::process_device_status
May 15, 2018 10:19:41.019 [0x7fb6d8567700] INFO - * v4l::DeviceGetList_impl. getting v4l device list
May 15, 2018 10:19:41.019 [0x7fb6d8567700] INFO - * v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
May 15, 2018 10:19:41.023 [0x7fb6d98ef700] INFO - * web_service_t::process_get_scanners
May 15, 2018 10:19:41.023 [0x7fb6d98ef700] INFO - * v4l::DeviceGetList_impl. getting v4l device list
May 15, 2018 10:19:41.023 [0x7fb6d98ef700] INFO - * v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
May 15, 2018 10:19:41.052 [0x7fb6da2b3700] INFO - * web_service_t::process_device_status
May 15, 2018 10:19:41.052 [0x7fb6da2b3700] INFO - * v4l::DeviceGetList_impl. getting v4l device list
May 15, 2018 10:19:41.052 [0x7fb6da2b3700] INFO - * v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
May 15, 2018 10:19:41.055 [0x7fb6d8f2b700] INFO - * web_service_t::process_get_scanners
May 15, 2018 10:19:41.055 [0x7fb6d8f2b700] INFO - * v4l::DeviceGetList_impl. getting v4l device list
May 15, 2018 10:19:41.055 [0x7fb6d8f2b700] INFO - * v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
May 15, 2018 10:19:43.967 [0x7fb6e0b8e700] INFO - * web_service_t::process_device_discovery
May 15, 2018 10:19:43.967 [0x7fb6e0b8e700] INFO - * device_reactor_t::get_device_list ()
May 15, 2018 10:19:43.967 [0x7fb6e0b8e700] INFO - * dvb_device_factory_t::get_device_list ()
May 15, 2018 10:19:45.971 [0x7fb6e0b8e700] INFO - * SAT2IP - server discovered: 192.168.0.101
May 15, 2018 10:19:45.971 [0x7fb6e0b8e700] INFO - * SAT2IP - description XML: http://192.168.0.101:9981/satip_server/desc.xml
May 15, 2018 10:19:45.972 [0x7fb6e0b8e700] INFO - * SAT2IP - get_frontend_num_dvbs
May 15, 2018 10:19:45.973 [0x7fb6e0b8e700] WARN - [E] sat2ip_streamer::open_rtsp_session. rtsp_client_.connect failed 192.168.0.101
May 15, 2018 10:19:45.973 [0x7fb6e0b8e700] WARN - [E] sat2ip_streamer::tune. open_rtsp_session failed
May 15, 2018 10:19:45.973 [0x7fb6e0b8e700] INFO - * SAT2IP - get_frontend_num: tune failed
May 15, 2018 10:19:45.973 [0x7fb6e0b8e700] INFO - * SAT2IP - get_frontend_num_dvbt
May 15, 2018 10:19:45.974 [0x7fb6e0b8e700] WARN - [E] sat2ip_streamer::open_rtsp_session. rtsp_client_.connect failed 192.168.0.101
May 15, 2018 10:19:45.974 [0x7fb6e0b8e700] WARN - [E] sat2ip_streamer::tune. open_rtsp_session failed
May 15, 2018 10:19:45.974 [0x7fb6e0b8e700] INFO - * SAT2IP - get_frontend_num: tune failed
May 15, 2018 10:19:46.379 [0x7fb6e0b8e700] INFO - * v4l::DeviceGetList_impl. getting v4l device list
May 15, 2018 10:19:46.379 [0x7fb6e0b8e700] INFO - * v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
May 15, 2018 10:19:46.384 [0x7fb6e0b8e700] INFO - * dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.0, Name PCTV 461, Standards 4
May 15, 2018 10:19:46.385 [0x7fb6e0b8e700] INFO - * onetv_factory::DeviceGetListEx >>
May 15, 2018 10:19:46.386 [0x7fb6e0b8e700] INFO - * onetv_factory::DeviceGetListEx. Found device 8211:600
May 15, 2018 10:19:46.386 [0x7fb6e0b8e700] INFO - * onetv_factory::DeviceGetListEx. Found device 2316:4096
May 15, 2018 10:19:46.386 [0x7fb6e0b8e700] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:3
May 15, 2018 10:19:46.386 [0x7fb6e0b8e700] INFO - * onetv_factory::DeviceGetListEx. Found device 1892:1281
May 15, 2018 10:19:46.387 [0x7fb6e0b8e700] INFO - * onetv_factory::DeviceGetListEx. Found device 32903:32776
May 15, 2018 10:19:46.387 [0x7fb6e0b8e700] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:2
May 15, 2018 10:19:46.387 [0x7fb6e0b8e700] INFO - * onetv_factory::DeviceGetListEx. Found device 32903:32768
May 15, 2018 10:19:46.387 [0x7fb6e0b8e700] INFO - * device_manager_t::get_device_list. Device PCTV 461, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.0, tuners 1, state 0, standards 4
May 15, 2018 10:19:46.388 [0x7fb6db63b700] INFO - * web_service_t::process_device_status
May 15, 2018 10:19:46.388 [0x7fb6db63b700] INFO - * v4l::DeviceGetList_impl. getting v4l device list
May 15, 2018 10:19:46.388 [0x7fb6db63b700] INFO - * v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
May 15, 2018 10:19:46.391 [0x7fb6da2b3700] INFO - * web_service_t::process_get_scanners
May 15, 2018 10:19:46.391 [0x7fb6da2b3700] INFO - * v4l::DeviceGetList_impl. getting v4l device list
May 15, 2018 10:19:46.391 [0x7fb6da2b3700] INFO - * v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
May 15, 2018 10:19:46.425 [0x7fb6e0b8e700] INFO - * web_service_t::process_device_status
May 15, 2018 10:19:46.425 [0x7fb6e0b8e700] INFO - * v4l::DeviceGetList_impl. getting v4l device list
May 15, 2018 10:19:46.425 [0x7fb6e0b8e700] INFO - * v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
May 15, 2018 10:19:46.427 [0x7fb6d8f2b700] INFO - * web_service_t::process_get_scanners
May 15, 2018 10:19:46.427 [0x7fb6d8f2b700] INFO - * v4l::DeviceGetList_impl. getting v4l device list
May 15, 2018 10:19:46.427 [0x7fb6d8f2b700] INFO - * v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
May 15, 2018 10:19:50.969 [0x7fb6d8567700] INFO - * web_service_t::process_device_discovery
May 15, 2018 10:19:50.969 [0x7fb6d8567700] INFO - * device_reactor_t::get_device_list ()
May 15, 2018 10:19:50.969 [0x7fb6d8567700] INFO - * dvb_device_factory_t::get_device_list ()
May 15, 2018 10:19:52.973 [0x7fb6d8567700] INFO - * SAT2IP - server discovered: 192.168.0.101
May 15, 2018 10:19:52.973 [0x7fb6d8567700] INFO - * SAT2IP - description XML: http://192.168.0.101:9981/satip_server/desc.xml
May 15, 2018 10:19:52.976 [0x7fb6d8567700] INFO - * SAT2IP - get_frontend_num_dvbs
May 15, 2018 10:19:52.976 [0x7fb6d8567700] WARN - [E] sat2ip_streamer::open_rtsp_session. rtsp_client_.connect failed 192.168.0.101
May 15, 2018 10:19:52.977 [0x7fb6d8567700] WARN - [E] sat2ip_streamer::tune. open_rtsp_session failed
May 15, 2018 10:19:52.977 [0x7fb6d8567700] WARN - [E] sat2ip_streamer::open_rtsp_session. rtsp_client_.connect failed 192.168.0.101
May 15, 2018 10:19:52.977 [0x7fb6d8567700] INFO - * SAT2IP - get_frontend_num: tune failed
May 15, 2018 10:19:52.977 [0x7fb6d8567700] INFO - * SAT2IP - get_frontend_num_dvbt
May 15, 2018 10:19:53.382 [0x7fb6d8567700] INFO - * v4l::DeviceGetList_impl. getting v4l device list
May 15, 2018 10:19:53.382 [0x7fb6d8567700] INFO - * v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
May 15, 2018 10:19:53.387 [0x7fb6d8567700] INFO - * dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.0, Name PCTV 461, Standards 4
May 15, 2018 10:19:53.387 [0x7fb6d8567700] INFO - * onetv_factory::DeviceGetListEx >>
May 15, 2018 10:19:53.389 [0x7fb6d8567700] INFO - * onetv_factory::DeviceGetListEx. Found device 8211:600
May 15, 2018 10:19:53.389 [0x7fb6d8567700] INFO - * onetv_factory::DeviceGetListEx. Found device 2316:4096
May 15, 2018 10:19:53.389 [0x7fb6d8567700] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:3
May 15, 2018 10:19:53.389 [0x7fb6d8567700] INFO - * onetv_factory::DeviceGetListEx. Found device 1892:1281
May 15, 2018 10:19:53.389 [0x7fb6d8567700] INFO - * onetv_factory::DeviceGetListEx. Found device 32903:32776
May 15, 2018 10:19:53.390 [0x7fb6d8567700] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:2
May 15, 2018 10:19:53.390 [0x7fb6d8567700] INFO - * onetv_factory::DeviceGetListEx. Found device 32903:32768
May 15, 2018 10:19:53.391 [0x7fb6d8567700] INFO - * device_manager_t::get_device_list. Device PCTV 461, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.0, tuners 1, state 0, standards 4
May 15, 2018 10:19:53.393 [0x7fb6dac77700] INFO - * web_service_t::process_device_status
May 15, 2018 10:19:53.393 [0x7fb6dac77700] INFO - * v4l::DeviceGetList_impl. getting v4l device list
May 15, 2018 10:19:53.394 [0x7fb6dac77700] INFO - * v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
May 15, 2018 10:19:53.397 [0x7fb6da2b3700] INFO - * web_service_t::process_get_scanners
May 15, 2018 10:19:53.397 [0x7fb6da2b3700] INFO - * v4l::DeviceGetList_impl. getting v4l device list
May 15, 2018 10:19:53.397 [0x7fb6da2b3700] INFO - * v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
May 15, 2018 10:19:53.431 [0x7fb6d98ef700] INFO - * web_service_t::process_device_status
May 15, 2018 10:19:53.431 [0x7fb6d98ef700] INFO - * v4l::DeviceGetList_impl. getting v4l device list
May 15, 2018 10:19:53.431 [0x7fb6d98ef700] INFO - * v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
May 15, 2018 10:19:53.433 [0x7fb6d8f2b700] INFO - * web_service_t::process_get_scanners
May 15, 2018 10:19:53.433 [0x7fb6d8f2b700] INFO - * v4l::DeviceGetList_impl. getting v4l device list
May 15, 2018 10:19:53.433 [0x7fb6d8f2b700] INFO - * v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
May 15, 2018 10:19:57.963 [0x7fb6db63b700] INFO - * web_service_t::process_device_discovery
May 15, 2018 10:19:57.963 [0x7fb6db63b700] INFO - * device_reactor_t::get_device_list ()
May 15, 2018 10:19:57.963 [0x7fb6db63b700] INFO - * dvb_device_factory_t::get_device_list ()
May 15, 2018 10:19:59.966 [0x7fb6db63b700] INFO - * SAT2IP - server discovered: 192.168.0.101
May 15, 2018 10:19:59.966 [0x7fb6db63b700] INFO - * SAT2IP - description XML: http://192.168.0.101:9981/satip_server/desc.xml
< i have to snip the log > because this piece of ■■■■ forum is not able to display such a “big body”. >
EDIT:
Now its working, the first time in 2 days.
I didnt changed ANYTHIGN (!!!) Plex Support, are you really sure your ■■■■ is working correctly?
Body is 9899 characters too long.
Fiox your ■■■■ forum, ic ant believe it. Biggest scam in history.
