Hi all
Hope some of you can help me out here. I have a Netgear RN314 and due to the PLex NAS compatibility excel, I should download the x86 package. However it seems like that is removed from the download section. Is there a way I can hold of the latest x86 package because I screwed my current installation up and cant’t get it to work.
Regards
To my
Great question! I may need to reinstall the PLEX media server on my ReadyNAS RN628X. The only thing on the download page is Intel 64-Bit. I don’t think that’s the correct download.
I used to use several readynas, as far as I remember, they should use the x64 package.
I don’t think the 32bit models have been supported for awhile.
it looks like only x64 bit and ARM devices are supported:
the intel 64bit package should work for your nas.
