The Xbox 360 app is a godsend, and I haven’t really run into many issues.
Unfortunately, there are a couple problems I’ve run into:
I have to enter my PIN every time I log into the app in Xbox. Not a big deal, just a little annoying.
Every time I play a video through the 360, it stops playing at 00:01:40-00:01:4 (every single time). I’ve tested this on a couple of Xbox 360’s that I have, same result.
Any tips/tricks for either of these problems?
Also… Any ETA on the shuffle feature being added?
Thanks again for this, it is overall amazing! Good work!
Hey I don't know if you had a chance to go through my post yet called "Xbox360 App Issue" but basically a lot of my problems went away by deleting the plex app, deleting the xbox cache, then reinstalling. I'll copy/past the final post here:
Yes, for me deleting the cache did the trick. Recall that when you read through those instructions they recommend you do it three times. I don't know why but that's what they say right above Step 1
My exact procedure was to go to settings, System, Storage, Hard Drive, Games and Apps, I then found Plex in the list then hit the Y button then hit delete so that way it deletes all three items under the Plex app. I then did the cache thing (in the link you provided) and reinstalled Plex and that's what did the trick for me.
