Xbox Controller not working Plex HTPC
Does this feature work with Plex HTPC and Windows 10?
I can see that Plex HTC recognises my Xbox contoller but it’s not registering any inputs to map
Logs say
Oct 17, 2021 12:42:03.811 [1064] INFO - [Input/SDL] Found 1 joysticks
Oct 17, 2021 12:42:03.812 [1064] INFO - [Input/SDL] JoyStick #0 is Xbox Series X Controller with 16 buttons and 6 axes
Logs also say controller never registers any input unlike keyboard
Oct 17, 2021 12:42:16.945 [10060] DEBUG - [InputManager] Input received: source: Keyboard keycode: Esc:3
Oct 17, 2021 12:42:17.065 [10060] DEBUG - [InputManager] Input received: source: Keyboard keycode: Esc:1
I’ve followed online instructions but have come to a halt.
Server Version#:latest
Player Version#:latest
I’ve been dealing with this issue myself. From what I can tell, there seems to be a bug related to controller detection on startup in the event of a pre-connected controller. Only thing I’ve found that works is to have the controller powered off completely, launch the HTPC app, and then after the screen is completely loaded, power on the controller. The workaround is annoying, but works on my system. Hopefully this is fixed soon. Can’t tell if this bug is present on all gamepads or just Xbox One.
