Xbox One Audio offset syncing
i’m playing a movie and the audio is a little behind off sync. Is there any way to adjust this? On my laptop you used to be able to do this easily.
Any help would be appreciated
Hi @blindstrom,
The only time audio has been out of sync for me is when the i have had " Allow Display Mode Switching" turned to on.
Is the audio going straight to your tv?
What is the audio type you have set in the audio settings on the xbox?
