prejudice to the last plex updated each time you open it asks me to re-enter all data. and all settings previously entered haunt them as default.
Hi there @ciavarrag. Since the last update settings are stored per Plex user. If you switch Plex user you will see different settings. Are you using the same user?
Yes .
IF setting plex for autologin next start this setting is not present.
Hello,
I’m having the same issue applying also to the auto sign-in feature.
Created a thread named “1.7.1.0 - Auto sign-in doesn’t work”
