Hi i have got an xbox one s and everytime i try to use the pin code to connect. The pin on screen expries within 10 seconds and tells me to refresh. So its useless have seen this issue commented on other devices but not on xbox one.
I have reset the console to factory default wiped everything from it and uninstalled the app twice. With the same issue still being there.
Can someone please look into this.
Does this happen in any other app like Plex Media Player? Just to make sure you are leaving it on screen without doing anything on the xbox and it is timing out by itself correct?
Yes it is timing out on its own. I put the controller down after i choose the app. It doesnt happen on anything else. The screen comes up code expired almost immediately has done all weekend have tried some 40 times now
Sent from Yahoo Mail on Android
On Tue, 28 Mar 2017 at 4:17, BigWheelforums+d264947-s6025034@plex.tv wrote: Plex Forums https://forums.plex.tv/
BigWheel commented on Xbox one s plex pin expires within 10 seconds
Meant to say i refresh it and it does it again. I have video of it that im uploading to youtube for you to view. I also have two controllers that i have tried independantly just incase it was one of them causing the issue. Amazon, netflix and xbox media player work fine. There is only one plex app available on.my one s as i just searched.
…please see next message has video in thanks
Sorry this video is from main home.screen including bootup.
Chris elwick
sorry that is happening. can you try uninstalling app, rebooting xbox and reinstall app. We have been testing here and cannot reproduce
Plex Media Player is our desktop/htpc app available for full computers. in full screen it looks basically like the xbox app and has the same code login system. No worries if you do not have a computer
Hi i have tried this many times i have lost count how many times i have u installed the app. I have even wiped my console and started from scratch and lost 700gb of games. It still does it.I dont know what else to do now.
On Tue, 28 Mar 2017 at 19:52, BigWheelforums+d264947-s6025034@plex.tv wrote: Plex Forums https://forums.plex.tv/
Hi i have tried this many times i have lost count how many times i have u installed the app. I have even just this minute wiped my console and started from scratch and lost 700gb of games and it still does it there is nothing else on the console apart from plex. No games or other apps. I dont know what else to do now.
Here is a video just to show the console is wiped clean no games or account data saved. Factory wipe and still plex is the only thing on the console and its still playing its little game. I also tried my 2nd controller aswell just incase it was doing something it shouldnt
Wiped xbox one s
Wiped xbox one s
Chris
P.s its 12am here so off too bed now. Cant try anything else as there is nothing i can think of.
just letting you know we are still investigating why this is happening to you. not forgotten
I am having exactly the same issue. Pin expires in 10 seconds can’t link to my iPhone just don’t get enough time
Just dont understand it. I tried installing plex on someone elses original xbox one console and it doesnt do it on theirs and it shows a lot more downloads of the app on their console than it does on my xbox one s. So god knows whats happening. Please help sort this out. I bought this console for its plex abilities. So at the moment i have wasted £200…
“shows a lot more downloads of the app” i’m not sure what this means. We believe it is network related but have not pinned it down yet
Hi
Have you had any luck finding a cure to this issue as yet? I deleted the app and reinstalled it and its no different.
Chris
I’m having exactly the same issue. I sent a ticket in already but was trying to Google solutions and found this thread.
The video he posted is identical to what I’m seeing on my xbox.
If there is any fix please let me know, I really need to sort this ASAP.
Thanks.
Running into the same problem here. I think its less then 10 sec for me, like perhaps 5. Kinda makes having Plex useless at the moment.
Hi ive been old by plex that the issue is network related, but they have no fix at present. Its been a week since i reported it and as of thursday they had only just worked that out. So who knows when it will be fixed. At least others are in the same situation. They may try harder now.
Fingers crossed.
I also have this problem. It only started when I replaced my original XB1 with a new XB1S yesterday. Pin code login is effectively useless.
Everything was fine on the original XB1
