Xbox One - UI and Android Integration?
Hello,
Very nice concept and it works very well but there some questions about the continuing development of the Xbox One app.
As of now I cannot remotely access my Xbox one app through neither my PC nor my Android devices. As I’m sure you are well aware Xbox one is somewhat taxing to navigate for searching and being able to cast from PC->Android->Xbox (entertainment system) seamlessly is key.
Then I discovered that there is no search function for the Xbox interface, anywhere. That makes the Xbox app quite impractical as now I am forced to spend 5-6 minutes every time I want to look for a song that has a title alphabetically distant from what I’m currently listening to.
Making the tablet, phone or even desktop app able to search and control the Xbox one, or whatever entertainment system, app would solve the whole issue and essentially eliminate the most difficult to navigate UI (xbox). Additionally I can guess that most of your client base would find this useful as they all most likely have smartphones, tablets or computers and an entertainment system.
At any rate, some updates would be nice, thanks for listening to my rantin’ and ravin’.
Have you tried using Xbox Smartglass on your PC and Android devices? I have no issues controlling Plex on my Xbone from either
I think what cdrubi is pointing out is that you can use your phone or tablet as a remote control for Plex on your XBox One but connecting to the XBox through Plex is not possible.
I have the same issue. I click on the remote control button and search for devices, but find nothing so I cannot use my phone or tablet to select a movie and play it on the XBox.
