Hi
On Xbox Plex shows only few movies in library when Android or Windows client able to list all movies in a folder.
All devices connected to a same network. I tried to reinstall Xbox app.
Where to look?
Hi
Where to look?
Just to clarify… I take it you haven’t applied any filters on the Xbox client that’s limiting which movies are displayed?
Also… you write of libraries and folders. Do you mean the library or a gap while displaying the same folders in folder-mode?
What’s the version of Plex installed on your Xbox?
Xbox - 2.132.0.70
Plex media server 1.30.0 on qnap
Library - folder on server which added to Plex with type of content (movies/tv show…) Not sure if that’s right definition according to Plex glossary.
Even 0+ cartoons are missing.
Could Xbox hide unsupported codecs?
