XML_ExpandNode - Error in cmd ADDXML
  • ATV3
  • DNS: 10.0.0.5
  • The local IP address: 10.0.0.5
  • The device and operating system: MB OSX 10.9.4
  • The Plex media server (PMS) version number: 0.9.9.10
  • The local IP address of the device that the Plex media server (PMS) is installed on: 10.0.0.5
  • The PlexConnect version number:  iBaa Pulled 7/11/2014
  • The contents of your 'Settings.cfg' file:
[PlexConnect]
enable_plexgdm = True
ip_pms = 192.168.178.10
port_pms = 32400
enable_dnsserver = True
port_dnsserver = 53
ip_dnsmaster = 8.8.8.8
prevent_atv_update = True
enable_plexconnect_autodetect = True
ip_plexconnect = 0.0.0.0
hosttointercept = trailers.apple.com
port_webserver = 80
enable_webserver_ssl = True
port_ssl = 443
certfile = ./assets/certificates/trailers.pem
loglevel = High
logpath = .
  • A detailed description of the issue (the clearer you can make this the better):
    • Plexconnect was working earlier today with some major hiccups here and there. Hiccups meaning: I would lose connection and then have to shutdown the server via terminal. Then she just stopped altogether. Library and Channels have ceased operation. Settings still works.
    • I shutdown the computer, shut down ATV3, reset the ATV3, reinstalled my certs, and shutdown the server several times.
  • Ensure you post your 'PlexConnect.log' file to pastebin and post the link:
http://pastebin.com/aTyuEqEC
Any help would be very much appreciated! Thank you in advance.
>> 23:30:11 XMLConverter: XML_ExpandNode: {{URL(:/PMS(//owned)/library/sections)}}
...just one example. Your PlexConnect version is pretty old. Yeah I know, it's the current version 0.3.1+ (we should up it to 0.4, I guess). Anyways, "//owned" is long gone. I don't think that this is the issue, though, unless you tried to combine it with third party themes.
Please update to the latest github code (if you don't mind), try again and come back with a fresh log...
Super strange. Even though I downloaded the most recent version of your art last night, it didn't work. Downloaded again this morning, it works. Thanks for the help!
http://pastebin.com/0rM8R3VS
