XMLTV Limitations
I am currently running 1.19.1.2645, with Xteve to connect my IPTV. It seems that there is a known issue with using an XMLTV for the DVR being limited to 20MB. Is there any way around this? I’ve had to cut back on channels to stay under the limit.
More specifically, the errors I am getting in the log when attempting to update the EPG is below
error issuing curl_easy_perform(handle)
Forum post noting this issue: BUG: 20MB XMLTV file size limit
Thanks!
The Plex team just posted a beta update to the server that fixes this. So when its released to stable channel you should be good to go.
That is amazing to hear, thank you for letting me know. I may just change over to the beta channel!
