Since the newest update I can now no longer use custom XMLTV. What is the solution?
When asking for a zip code, enter an invalid one, like 0000
didn’t work for me
Define newest version, and what webclient you are using.
And suggest using the bundled one, not the one from plex.tv for this issue
Nevermind. I tried that earlier and it didn’t work. Tried it again, and 00000 worked. Thanks for the heads up. They should put that info on their website.
They are working, so blood is flowing from their fingers to fix this instead ![]()
Thanks for the update!
