XMLTV Load, Result is "Unknown Status"
Server Version#: 1.18.1.1973
Player Version#: N/A
Trying to load an XMLTV file (as the new EPG is causing me a lot of grief … :frowning:). From the log though, I’m seeing this error on load,
Oct 19, 2019 18:06:17.482 [3780] ERROR - XML: Memory allocation failed : growing buffer
Oct 19, 2019 18:06:17.482 [3780] ERROR - Error parsing content from "XXXXX/zap2xml/ota.xml".
Oct 19, 2019 18:06:17.488 [3780] ERROR - Error parsing XML: Error parsing file.
Any suggestions, things to try?
Thanks!
OK, I tried shortening the file - only 3 days of info. Then it loaded. But that’s not real handy … :frowning:. Some sort of memory allocation failure?
Thanks!
Somewhat confirmed - if I try ~ 7-10 days … crashes. Shorten the file to 3 days, and all is good. Is there a limit on the file size?
Thanks!
A bit more of a nugget … :wink: If I try to use a 7 day file - NP. But 8 days … and it breaks. Perhaps an issue with the day of the week being “reused” somehow?
Thanks!
