Hii
Just installed Xplay on my 43f770 lg tv and its workng like a charm thanks.
Was wondering if there was any way or any plan to manually have the ability to zoom screen size in and out like you can on xbmc which i was using on my apple tv2.
Had to update the atv2 and lose the jailbreak in order to use the airplay feature so now no longer have the xbmc player
The zoom feature to lose some of the heavy margin bars was a really great feature of xbmc. I know on the lg you have the option to change screen size from original,full and zoom but they all look crappy.
I just want a feature that you can manually zoom a little bit just to lose some of the black bars without distorting the picture.
Many thanks
Baz
