XPlay (WebOS)
Already known bug.
@silverbullette said:
I don’t know if this issue is already known.
The seek bar doesn’t display the right play time when I move over it with the magic remote.
So it is not possible to move directly to the wanted time to play.
XPlay 1.2.2
PMS 1.2.7
@Scott190489 said:
Hello I believe there is an bug in last updates. In the Timeline bar in videos the end of the yellow line should be the current minute+second of the content I am watching. After the last updates this timeline dont work correct.
The time is not correct and also you cant navigate correctly in the timeline.
Уважаемый @bublikoff ,
Возможно ли регулировать настройками ширину левой панели со списком библиотек? У меня есть некоторые библиотеки с длинным названием и из-за узкой панели не видно даже их смысла названия.
Как вариант можно ли сделать возможность настройками менять размещение панелей, как по вертикали (правая и левая как сейчас), так и по горизонтали (верхняя - список библиотек, нижняя - ее содержимое) ? Тогда у кого длинные названия библиотек смогут корректно их видеть.
@bublikoff said:
I was thinking to support them … current version for webOS is actually support latest NetCast … but last try I tried to run it on NetCast emulator I had some issues. And I dont fully understand why they happen. As I remember there was a problem with HTTPS resources communication. Ive tried to ask about it on developers forum but did not received the answer. It might be a problem of Netcast emulator. And as Ive no real NetCast TV for testing I give up with this idea … at least for the moment
Thank you for your response. Is there anyway to download the current webos version and try to run it from an usb key ?
@bublikoff , can you post wend its safe to upgrade to latest PMS im still in 1.2.7.
Regards
Where I can get my user ID ?? It works good on my LG 55E6V !
@no-fri I have the same TV - believe I saw the user ID next to my Plex ID on the settings screen (click the spanner icon - top-left-ish on that next screen).
When you have some free time if possible to add remember last chosen user and auto login setting, remember pin too if enabled in settings. Would be nice feature to have if possible. Thanks :slight_smile:
Sometimes theme song continues when I start a TV show. Then I have to close the Xplay (exit+close the app) then open it again.
Hello. I have some performance issues when watching 4k hevc 10 Bit.mkv files via LAN on LG 55UB850V web os 1.4. I use direct play. Same movie works via usb on the TV. I am not sure whats the reason, xplay or my NAS power. The files are about 60 Gb and the LAN connection should be enough with 100Mbit connection(all components have 1gbit lan.but the lg have 100 mbit). Anybody have the issues or experience with it. The movies pictures and sound stutter.
@Scott190489 said:
Hello. I have some performance issues when watching 4k hevc 10 Bit.mkv files via LAN on LG 55UB850V web os 1.4. I use direct play. Same movie works via usb on the TV. I am not sure whats the reason, xplay or my NAS power. The files are about 60 Gb and the LAN connection shoukd be enough with 100Mbit connection. Anybidy have the issues or experience with it. The movies pictures and sound stutter.
I had the same and (in my case) it was NAS power (but depends on the NAS as of course). When I served the same movie from a laptop with Plex Server it played fine.
I had the same problem with my WArcraft 4k hdr 66gig. A lot of stuttering. The problem was my network. I changed some switch connections et solved that problem. The image quality et fluidity is perfect like with my Roku ultra. But with this video, i have an other problem with sound. My default language is french. When I start the movie with french language selected the language played is english. Its very weird and I never had this problem with smalest movie (15 gig and less). No problem with my Roku ultra.
Hello. What did you changed in your network. cant believe that my home network is the problem. using 1 router and one switch behind nas and lg tv with 1 gbit. I will check my data priority settings in the router.
Did you tested the language on your pc? maybe and wrong named language track. direct play or transcoding? also it couldbe that the english track is forced in the mkv. so you have to modify the mkv to force the french audi track. not difficul.
Hi… I just bought an LG OLED55E6V. I’d like to test your app, but when I start it and enter plex pass code (user control) it freezes… Is there anything I’m doing wrong?
Can anyone tell me if xplay on Webos 3 supports Replaygain for FLAC-Files?
Sometime cheap switch can have conflict or problem. You can try some test like remove component in your network.
When I pluggeg my tv directly in my router instead the switch the problem of stuttering has been resolved. Also the roku Ultra have a Base T 100Mbits only and no problem with him with the same movie. For my problem of language, With the Roku I can play the same french track and no problem. I understand what you said to modify sound track but in my case is not the problem…
@Didier3L said:
Good evening, here france ;))
I initiated a multiplexing of the video file with a single forced subtitle.
Xplay does not require transcoding. :slight_smile:
But badly displayed subtitles
Heberger image
What format of subtitles u use? Can u share subtitles file? or its an embedded one?
@miff88 said:
just to confirm… i’m able to update my PMS to the latest version and xplay will still function correctly?
also, will you be releasing the screensaver in the next release you send to LG?
Yes … I already implemented screensaver for current developer version. As I remember Ive already posted a sample animation in this topic
After update the app is not working anymore it shows the main page but when I click on a movie it shows the xplay logo and the spinning circle. What can I do?
I fix this issue was a bat IP on my tv but now I can’t see the whole movie images, the app cuts the half of the movie with a black screen, I tried with other apps and movies are OK, this also started after update, any help buddies?
Check past several pages in this topic … its known problem … Ive already fixed this issue and posted fixed version to LG QA … for the moment we can only wait …
I’ll check what can be wrong with it
В текущей версии это точно не возможно. В виду того что дизайн жестко завязан на размеры и координаты элементов. Можно подумать что можно сделать в будущей версии … там список библиотек всего лишь “высплывающая” панель и хоть на весь экран можно при желании растянуть
