XPlay (Android)
XPlay (Android) is the Android version of XPlay app (read more about it here: https://forums.plex.tv/discussion/168315/xplay-webos/p1)
The app primarily designed for Android TV and Android boxes that work on Android 5 and higher. Then the app was adapted for smartphones and tablets.
If you have any thoughts and suggestions, please let me know! I will appreciate much any reasoned opinion
WWW: http://xplay.itkey.ru
On Twitter https://twitter.com/XPlay4Android
Get it on Google Play
Bug tracker: https://github.com/dirondir/xplay-android
Some examples :
You should polish UI )))
Hi, I would like to test the android version
Hi!
I’m polishing UI and fixing known bugs… It takes a little bit more time than I expected. But I work hard to release the app this month.
Hello, I love the idea of working on xplay for android TV
I would like to test it.
Hi can I give your app a test
Happy New Year to all of you.
It will be fantastic to have Xplay ported to Android.
I just found it yesterday for Webos 3.00 and I am really satisfied. I am buying it in the next few days.
I am interested to be able to try Xplay for Androdi if possible.
Best regards
@DironDir said:
Hi!
Hello everyone, Happy New Year!
@DironDir I hope you can update us on what the application for andorid Tv is going for.
Are you still working?
Have you abandoned it?
I am interested in being a tester, of course if it is still possible.
Strength with the project !!!
Excuse me for my English: v
Hi everybody!
Sorry for long silence from my side.
I got technical issues with playing video and it took time to figure out how to deal with it
The road map is now:
  1. Own testing of playing movies\shows railers\musics, photo viewer…
  2. Add some settings for customization
  3. Polish the UI a little bit
  4. Publish and begin testing
There is the small video below, how the app looks right now
[](https://youtu.be/wpqteJz06wo “”)
Looks great, I’m very much interested in this. How soon can I replace the big riddled Android app from plex?
I plan to release alfa-version of the app in February. More likely in the second half of the month
Love to get in on the testing as well
For better understanding let me know what kind of Android TV devices you use with Plex Server.
Type - Android TV or Android TV box, Android version
Right now I’m testing the app on Android 5 and higher. Does it make any sense to test it on lower versions?
Hi how about adding a vertical smart stretch feature so no black bars = full screen (UNLOCKED USER)
If you mean filling all the screen, yes it will be in the app. Take a look at the example below
Default
height and width
height
Hello :slight_smile: I would love to test this Xplay App on my ShieldTV, i love it on my LG OLED but thanks to HD Sound i have to use Plex or Plex AddOn for Kodi…
Maybe i could test something for you, let me know! :slight_smile:
It looks like we have enough testers :smile:
Thanks everyone in advance
Thats too bad :frowning: I wanna try it! Guess i´ll just have to wait then :slight_smile:
Don’t worry you are in
It’s all my terrible English :smile:
Where exactly was the sign up for this, as I would have applied, thanks.
