XPlay (WebOS)
just scan gets me the full picture.
But stretched to fit the entire screen - out of proportion people and things…
this is really odd.
but good suggestion!
When can we expect the next update to X Play? The text that Xplay displays on the menu are still a little blurry in 1080p compared to the previous version, so I am very much looking forward to the next update.
Hi
I don’t see any option to search by folder when accessing my NAS through XPlay on my LG OLED TV?
Hi, I got a bug:
  • get 2 servers
  • shutdown one
  • try to connect from xplay to the one which is down
  • got a popup “impossible to connect”
The problem is that the popup can’t be discarded. Clicking on the X or the Close button bring the LG menu as if pressing the Back button of the remote. I had to turn the TV off/on to get it back.
One more bug.
Trying to change Settings -> User ID using backspace exits Settings.
Workaround: Use Clear All and rewrite correct User ID.
this is really odd.
tried all others ?
@niskruse said:
@bublikoff :
I have plex server in stalled on xubuntu server.
Newest version.
Newest Xplay on LG TV
It allows me to choose the user (have plexpass) but then refuses to connect to the server it simply says i can restart or retry
Both Plex official and PlayZ work fine.
As I know PlayZ does not support Plex Home Users. Its hard to say what can be wrong … In my test environment Home Users work well. And think that without accessing to problem users I cant discover what can be wrong with them
@ConcreteLlama said:
So as far as I can tell there are 2 bugs:
  1. It’s not playing the audio stream that’s selected
  2. It’s unnecessarily transcoding the other streams.
  1. Its a bit hard to work with audio streams on webOS … and not possible to select them without transcoding other then default stream (I hope that the situation has been changed). I can only try to check what information PMS returns to the app and maybe the app just dont correctly detects default stream
  2. see 1. … webOS does allow only work with default audio stream without transcoding. At least its true for web apps for webOS platform
@Scott190489 said:
Hello, one new problem. Movie Information while watching a movie dont showing the picture and name of the movie in the left corner above.
Its probably better to wait the latest update … I thing that this bug was fixed. Current version has UI scaling issue and it probably can lead to such issue
@petercris said:
Same here
Any solution?
Thanks!
Try to wait the latest update …
@niskruse said:
@bublikoff I have had Aspect Ratio problems on all verisons for Xplay.
On all?) what versions?)
See pictures below for reference. This is ALWAYS the case.
It seems like the video sent by the server is 4:3?
I’ve uninstalled Xplay. Uninstalled Plex server - installed plex server on completely new system (QNAP–>Xubuntu). No difference. I think it may be the TV as a friend of mine with different TV does not have this issue?
plz plz help.
This is killing me Xplay experience.
I’ll buy the program once more if I have to:)
Pleas wait for the latest update … I hope to get response from LG QA … if they approve this update or reject.
Probably today … Im trying to push update for already a month … since December … LG QA rejects rejects and rejects it again) It has some UI scaling fixes … and I hope it will fix cropped picture issue
Current version does not support “By Folder” view mode. But Ive already finished this functionality in the new version.
I finally get back the work on new the version after problems with LG QA past December … I had to stop all works … it was time of depression))
Ive even posted a small pool in Twitter
@doegox2 said:
Hi, I got a bug:
  • get 2 servers
  • shutdown one
Can you film it? I’ll try to check the app logic
@argosieger said:
One more bug.
Trying to change Settings → User ID using backspace exits Settings.
Hi Argo)
Is it possible to correct User ID?)) or you are speaking about User-Agent String?
Yes, I’m talking about User-Agent String (not User ID - my bad)
And yes, I can correct UA String if at first I press Clear All and then rewrite correct UA String.
The bug is that I can’t use Backspace (to delete last letter for example) which exits Settings interface.
@bublikoff said:
@argosieger said:
One more bug.
Hi Argo)
I need clear answer for following question about latest PMS Version 1.3.3.3148 @bublikoff
I am using latest version of XPLAY on LG Store. I saw new PMS update Version 1.3.3.3148. Should I update my PMS? Thanks for all answers…
If you do not need filters for selecting videos by watched/unwatched, by genre, by year etc, then you can update.
If you need filters, then stay on 1.2.7.
P.S. Latest PMS version is 1.3.4.3285
like @mkaand , i will not update anything unless @bublikoff tells us Xplay works with PMS 1.3.4.3285 :smiley:
Just updated PMS and it works fine with XPlay
