XPlay (WebOS)
@randyippolito said:
Don’t know if it will help anyone but I had to factory reset my TV in order to update it which required an Xplay re-install. I couldn’t get it to work, I’d click on my user enter my pin and just spin forever. The I tried my main user (which I only use on my server for administration), that logged it into the server now all my other users work and I am using it right now. Probably basic stuff but it was frustrating for a little bit!
Can you share access to this user that have problem with XPlay? I’ll check what it can be.
As Im not a PMS developer I can not predict all variants of PMS behavior and to fix issue I need more tech details.
PS
Of course its up to you =)
@charliesimba said:
Apologies for the long post. I know this question has been asked many times before but I have been trying to get XPlay to install for months on my LG tv with no luck. I can’t watch anything on my LG Plex app anymore without freezing or buffering and it doesn’t log in automatically either - I have to type a pin code in sometimes 5-10 times until it decides it wants to work, as it doesn’t remember to Sign In Automatically. I have reset my tv numerous times, reinstalled the app, downgraded the software, transcoding, direct play and direct stream settings and more but it constantly comes back with errors. The short of it is I need to find a way to install XPlay, so I don’t have to use the LG Plex app anymore.
My LG is a 55LA690V-ZB with software version 04.28.14. I have tried to install XPlay on 3 different USB sticks formatted to Ex-Fat, with only the 1 unzipped developer folder. When I plug this into my LG tv, I can see the delevloper folders but it does not display the actual app. I have signed in and out of my LG account and tried all USB ports on my tv but it still doesn’t display the actual app. I would really appreciate any help to get this working for me! My last resort is to buy an AppleTV to use Plex this way, but I would rather use XPlay after reading all the feedback over the years. I really hope you can help me, you’re my only hope!
Its better to use version from LG Apps store … USB version is outdated and does not work with new PMS version 1.3 and upper
@Deihnyx said:
I have the same issue with subtitles (SRT, all OCRed with the same tool). Only one of my movies have the subtitles working.
I tried embedded and external and no luck.
Also some audio tracks are swapped. I select the AC3 and it plays the commentary track (in a movie with TRUEHD, AC3, AC3 commentary).
Have you tried for eg to play it using PMS web client?
Also if it helps, the one movie where subtitles are working have only one audio (DTS), one subtitle (PGS) and one SRT (this one works).
On the non working movies, there’s at least 2 audios (TRUEHD and AC3, because TRUEHD doesn’t seem to work with the E6), I will try with another movie with only 1 DTS to see if the subtitles work, maybe it’s related…
The OS is WebOS 3. (LG E6)
Hope that helps with the issue.
@Denna93 said:
Hello. SRT external subs doesnt work on my LG uh635 TV. Used to work but now it just doesnt show any subs
Can you share any SRT subs for eg? I’ll check on my side
New major version update already looks amazing. If you need any beta testers, let me know. Happy to help!
I’ll add option to change behavior in next major version. Next major version will actually have much more options to change the app’s behavior
Im unsing xplay now for a few days and I love it. If possible I would like to have the screensaver which shows the fanarts of my library. Thank you very much for this awesome app.
@hel0 said:
If possible I would like to have the screensaver which shows the fanarts of my library. Thank you very much for this wesome app.
Even did not think about screensaver this way … I’ll think about using media arts in screensaver …
Question for bublikoff…
I just bought another LG TV, I haven’t signed into my lg store yet as I forget my password and my pc is down at the moment.
So I downloaded a play and signed in using my Plex pass. Will that be all I need to do to keep it from the trial version or do I’m need to read download from my content store?
First of all, thanks for an awesome job!! I bought the full version a couple of days ago because the official app transcodes unnecessary videos and you seem to be way more active with development. Keep up the good work!
But my problem is this: yesterday I noticed that Xplay handles subtitles incorrect if you have several different subtitles downloaded for the same video. Even though Xplay recognizes that there are several subs, and you can choose them all, they don’t seem to play correctly(The video displayed french text instead of the chosen english for example) .
If I play the same video with the official Plex app, the subtitles are correctly shown.
What might cause this?
Thanks, I would appreciate it with another donation to you if this feature could be in future versions of the app!
For me, XPlay is perfect on my webos 1 tv, simple and efficient. I am just waiting for an interface refresh :smile:
@bublikoff just bought xplay. It rescued me when the official client wouldn’t direct play. Thanks for your work.
@Samsheep said:
Hi, One more vote for making the switching of audio tracks on webOS 3+ available!
Great product, BTW - keep up the good work
Has this regressed in the latest version? Can no longer switch audio on 4K files without it being transcoded.
Version number is 20170202.1.2.8
An example is the Planet Earth II series in 4K which encodes with Russian as the default audio language. In a previous version of XPlay you could change the audio to English (the second encoded audio language) without transcoding.
This no longer seems to be possible in the current version?
Your version is old. 02.02.2017. You have to force the update.
How to force the update?
First, try to unnistall the app and install it again. Then you may see the new version.
@bublikoff Thanks for the XPlay app, I finally can watch all my movies without stutter, much better than the official Plex app for my LG smart TV.
Anyone know how to get support for this app? Official email is not responding and this isn’t the place it seems like. Also, has anyone had any luck getting a refund?
Drop your problem here and maybe we can help. I really hope @bublikoff will have time to work and further improve XPlay (although it’s already pretty good), because he seems very busy. Hopefully he will open-source it if he won’t keep working on it. We need XPlay!
wich is the last online version of the app?
I can see 20170514… is it the last?
I also have a problem… often happens that the audio track selected (italian in my case) starts in english, I then switch to english (the first, with T transcode symbol) and then turn back to italian again, that need to be transcoded even if it’s shown without the red T symbol…
Roberto.
