XPlay (WebOS)
@Nielsvk said:
Bublikoff, most of the people only watch the last page of an topic. I think not everybody is aware of the fact that you are posting new versions of your Xplay app on a daily base by editing your first post.
Maybe an idea to post your new versions in a new post at the end.
Ok, I’ll inform about version bump) but for the moment are really not important just some UI experiments and improvements BUT every new upper version resets demo period)
Mega.co.nz gives me most of the time an download error.
Hmm … probably it’s problem with your computer because you are the first person who reported about this problem. BUT welcome to mediafire))) http://www.mediafire.com/download/ybj5ao0pf0majm0/XPlay-1.0.15-20150813-01-Demo.zip
Some ppl asked me to use “Previous” and “Next” actions on magic remote to use them as “rewind” and “forward” … so here you are))) When only one video is in queue “Previous” and “Next” actions can be used as “rewind” and “forward”
https://mega.co.nz/#!igF1wYhA!2EuL8O3udEU03fg4lUglzxS9syBBwbDUYzS2f3smyjw
http://www.mediafire.com/download/kypig6aknbptaw6/XPlay-1.0.15-20150813-02-Demo.zip
Thanks, gonna try your new build this weekend, and the downloadproblem was Safari, Firefox has no problems downloading the file.
Testing the latest build. Found a bug.
Using the d-pad left and right causes the screen to scroll up and not scroll back down.
Bonjour,
Je suis nouvel utilisateur de Plex et de Webos. Plex et PlayZ ne sont pas disponible sur ma TV (LG50LF652v). Je vais tester cette application qui m’a l’air très bien. Mais comment se la procurer au bout de la pèriode d’essais?
Merci.
bonjour
Juste attendre jusqu’à ce que je suis en mesure de contourner LG AQ)))
Maintenant, la seule façon d’étendre l’application de mettre à jour à la dernière version. Chaque nouvelle version de la période de démonstration, et réinitialise les 10 prochains jours, il va travailler sans restrictions
Using the d-pad left and right causes the screen to scroll up and not scroll back down.!
Got it! … And will fix in next version.
PS
to tell u the truth it’s already fixed) but I’m not going to share it today)
I cannot wait to get home and install this bad boy. I have been keeping up
to date with all the updates. In Chicago on vacation til Saturday.
happy holidays to you )))
Très bonne application. Serait-il possible d’ajouter un filtre Genre pour le tri des vidéos?
Je prévois cette fonctionnalité, mais plus tard. À l’heure actuelle, vous devez avoir au moins quelque chose à publier dans le magasin de sorte que vous pouvez utiliser sans autres problèmes. Les plans comprennent l’ajout de support de la vidéo en plusieurs parties, les filtres, le dossier de navigation, l’interface multi-langue, et l’interface formlenie éventuellement définir
New version … new cookies) Now current video info (while it playing) can be called by “info” key on ordinary remote, assigned on color key action or just by clicking video title
http://www.mediafire.com/download/910hc0i01ph9ui3/XPlay-1.0.16-20150814-03-Demo.zip
Cette nouvelle version ne fonctionne pas sur ma TV. L’icone de l’application n’apparait pas dans mes applications.
Ceci est probablement un problème avec le lecteur USB. Essayez de vérifier les erreurs. Parfois, si il ya des erreurs sur le disque ne veulent pas de trouver l’application TV.
PS
Et oui cette demande seulement pour webOS ))
à un autre point, la structure du dossier devrait ressembler
[USB DRIVE] :\developer\apps\usr\palm\applications\com.itkey.plexclient …
“com.itkey.plexclient” Il devrait contenir des fichiers
hehe je l’espère sur Google Translate traduit correctement))) plus ou moins, je sais que la langue Anglais Français … Je ne sais pas, je sais)
On va bien arriver a se comprendre. Je regarde et je refais un essais.
J’ai tout revérifier mais cela ne fonctionne pas.
Essayez de sortir et puis connectez-vous en utilisant votre compte chez LG Smart TV
Quel est le modèle de votre téléviseur?
