XPlay (WebOS)
Version bump http://bit.ly/lgxplay_1_0_22
  1. Ordinary remote navigation on settings screen
  2. Slightly increased font size in some places to meet LG requirements
  3. Ordinary remote page (channel) buttons can be used to scroll pages
Will changing audio/subtitle on direct play supported in the future or it is not possible (w/o transcoding)?
Its not possible due to lack of support bult-in audio/subtitles in html5 video player … I can try to add external only that is supported by html5 video player
Let us pray for XPlay … lol))) I’ve finally submitted XPlay to LG QA
but by the way … I’m going to add multilingual interface while LG approving XPlay
Thanks for your job!!!
Do you know how many time takes LG to aprove your app?
If you need any help with the translation to spanish I can help you…
Don’t know exactly but probably about two weeks
I settle to disable subtitles in the MKV
For the rest, the application is nice and clean interface
Its impossible to disable (change) built-in subtitles or audio tracks if it enabled in media container (such as mkv) in direct play mode … I cant control built-in subtitles or audio tracks because of lack of support in “html video player” … only PMS can disable them but it requires transcoding and much more CPU power on PMS side
PS
I can try to add support of external subtitles in direct play mode
I saw in playz that they use player.audioTracks and change the track via player.audioTracks[ind].enabled = true / false, doesnt that works or this is what requires transcode? Sorry for the noob question, i dont know much about webm
IIRC changing audio track in plex webplayer works in chrome with webm w/o transcoding.
Yes, It does. Html video player cant handle built-in audio tracks or subtitles only external. For eg if your movie has external subtitles I can handle it but it subtitles are built-in to mkv container player cant handle it. In case of transcoding … PMS just re-encode container to remove or switch between them
Hi, I’m using an ordinary remote and after I’ve signed in to my Plex account, I’m unable to select a server. Any thoughts on improving this?
Hi … for the moment it support only one server without signing-out … but we can plan this feature on next release.
just a little off-topic message … hehe))
According to dowload stats … bunch Plex + LG WebOS is the most popular in Hungary))
Almost double the difference from the nearest “competitor”
Is there any way to “disable” subtitles? I have mkv with internal subtitles. on web there is option with “none” but in xplay they are forced!
What u on web when u say “on web”?
PS
I dont force anything … html video player plays it AS-IS
This is screenshot from PLEX webUI. When using this LG TV via WebBrowser there is also an option to select “none”
but in XPLAY I can’t find it anywhere so the romanian are forced :frowning:
There is no magic … Web Client uses transcoding
go in Xplay —> Settings and disable the last option with the massage “…AS-IS…”. That should work with sub´s. when you disable this option your “Server” transcode the files.
Is thats right @bublikoff ?
PS
I love the As-IS setting and use it only, that is very nice (3%CPU work on server side)!!!
Well I’ve tried that. But the subtitles will be shown as they are still “forced”, Selecting none is necessary in WebUI.
Anyway thanks. I ill stick to non subtitle releases for now
