Any issues? any comments? is everything ok?
At the moment, i can say everything is okay. Later i tray varius codec´s but i think it´s all ok =).
might want to consider release using smart tv alliance - bigger audience …
So far so good. Wasn’t sure whether this was just me or whether intended but it appeared to load much faster than the previous version. Will let you know if anything comes up
I have found a bug in the new version. When in a TV series folder level with episodes over 2 pages, you can not move to the 2nd page to see episodes over 18. Can not move via scroll wheel no by using the D-pad to select the right arrow “>” and selecting.
Quite possible … it has about 20-25% rewritten o deleted redundant code but not sure if it increase UI the same value)))
Ye … Ic … I’m gonna fix it soon
Sorry for my english
I have a problem to connect to my PLEX server with the 1.0.20.
The screen is blocked on XPlay
XPlay 1.0.17 works
My LG TV 55UF778V
XPlay 1.0.17 works
My LG TV 55UF778V
Check PM
any news?
hey … have fixed episodes scrolling but waiting @sgfred )) but it seams to me that he is quit))
and this weekend I’m planing to start preparing presentation for LG QA … just have lack of time =(
very nice =)! Non Problem, i hope the LG QA team make no problems =). good luck! Btw thanks for the information, update and your work!
Does any body have play interruption issue?
i have no interruption issue
Version bump http://bit.ly/lgxplay_1_0_21
- Show episodes scrolling fixed
- Seeking in transcoding fixed
- Some times XPlay does not start or its impossible to sign-in is also fixed
First I really like this app, far better than playz, but I cant do anything in settings, unable to navigate to any option via the dummy/standard remote controller. Also it is possible to switch pages via button? (e.g. with program up/down
Btw It shows that it will expire in less than 10 days, but I was unable to find it in store or way to unlock the demo mode.
Hi
Ah ye … will fix it soon
U can use seek on next buttons or u can use function buttons
For the moment there are no ways to get full version … I’m working on pushing to to LG Store but u can use upper version which will reset demo period and start counting it from 10 days again
@asturel
Check PM for fixed version
No issue experience here so far
Watched 2 3D movie with XPlay-1.0.21-20150829-Demo.zip, no issue at all. thanks for the fixed version (meanwhile I workarounded with lg magic remote app)
Magic remote will always be a better variant of controlling such apps like XPlay )) but LG require ordinary remote to be supported)
