xTeVe - IPTV for Plex DVR
Aaaah ok so my problem here is that each m3u allows one stream at a time so I purchased 3 to allow 3 users so this isn’t going to work?
so 3 separate accounts that only allow 1 stream at a time each still = 1 stream at a time through xTeVe
but
a provider that allows 5 streams (like vader) = 5 streams at a time through xTeVe with 5 tuners?
Hmm so there is no work around for this then, I need to change my provider
Yes, exactly, 5 streams = 5 tuners
cool contacted my provider because I am really happy with them but looks like they are not going to be able to offer this
Tested for myself - works beautifully! :grin::clap:
panic: runtime error: invalid memory address or nil pointer dereference
[signal SIGSEGV: segmentation violation code=0x1 addr=0x40 pc=0x64c36c]
goroutine 1 [running]:
updateClient3.postRequest(0xc420089320, 0x0)
/Users/marcel/go/src/updateClient3/updateClient3.go:381 +0x80c
updateClient3.getVersion(0xc4200894d0)
/Users/marcel/go/src/updateClient3/updateClient3.go:284 +0x172
updateClient3.CheckUpdate(0xc420089320)
/Users/marcel/go/src/updateClient3/updateClient3.go:63 +0x27
_/Users/marcel/Documents/go/workspace/iptvpmsproxy/src.binaryUpdate()
/Users/marcel/Documents/go/workspace/iptvpmsproxy/src/config.go:256 +0x1f5
_/Users/marcel/Documents/go/workspace/iptvpmsproxy/src.Init()
/Users/marcel/Documents/go/workspace/iptvpmsproxy/src/config.go:171 +0x72c
main.main()
/Users/marcel/Documents/go/workspace/iptvpmsproxy/xteve.go:93 +0x6da
Trying to run this inside a freebsd jail, any idea how to fix this? or is jails out of the question?
Do you have an internet connection in the Jail?
i sure do.
Edit:
btw, its an iocage jail running on 11.2-beta1 freenas if more info is needed :slight_smile:
Are you coming from the FreeBSD Jail to the internet ???
Yes or no?
yes the jail has internet access :slight_smile:
Execute this command in the Jail:
curl -I -L update.xteve.de:9000
HTTP/1.1 301 Moved Permanently
Content-Type: text/html; charset=utf-8
Date: Sat, 11 Aug 2018 08:53:26 GMT
HTTP/2 200
access-control-allow-headers: Content-Type
access-control-allow-origin: *
date: Sat, 11 Aug 2018 08:53:26 GMT
Delete xTeVe and download it again.
There we go :slight_smile: works great now :+1:
And what was the problem?
Currently I am working on the public version of xTeVe.
Here is a small preview of the new version.
Sort and mapping channels in the web interface:
This also works over several XMLTV files.
xTeVe generates a single XMLTV file containing only the required channel and program information.
In my case (about 60 channels), XMLTV file is rugged from 120 MB to 3 MB.
For me, the Plex hit rate at the match was 100%.
But I still need a few XMLTV files to test.
So who has any, can feel free to contact me.
Don’t know what the problem was, re-downloaded the binary and it works :slight_smile:
And I have to say, this piece of software is amazing. great work!
Im sorry but this guy has took code, taken it made it look pretty and locked it away so users dont know what the hell he is doing with it. If you want to go to the original coder of this the go to https://github.com/tombowditch/telly.
yes the link I provide is more barebones but its not hidden behind scam keys and fancy ui’s.
:joy: Not a line, but thanks for the recognition and for your first post.
But you forgot these projects:
But I’ve probably forgotten a few more :thinking: :sunglasses:
