Very strange, you are already the second with the problem.
In the Bata phase, there were about 30 updates and there were no problems with the update. Which operating system do you use?
Have you already mapped the channels in xTeVe? Menu Mapping. The channels must be green
This was the same issue that I had - following an update all of the channels in mapping has been disabled (turned red). I just reactivated (right click the ID) and it worked fine
Yes, you are have right.
Save the tmp folder somewhere. If after an update of the M3U and XMLTV file the assignment is lost send me the old and the new M3U and XMLTV files.
Question. I have 2 XMLTV files and use the XEPG feature. All is good. When I go to configure xTeVe as a tuner in PMS, it asks me to select country for EPG, or use my own XMLTV. How do I point PMS to used the combined xTeVe XMLTV?
Thanks, love this ability to use my IPTV service in PMS.
It would be great if the M3U could be updated manually so it doesn’t have to update both the EPG and M3U.
Hey everyone,
I am sure this has been asked before but could you provide a simple answer.
My provider sends the m3u file with m3u8 extensions. Do I have to find another provider or is there a way to convert?
Hobs
Or via the link: Mapping -> Show XEPG
Yes, it has already been asked.
With many providers, you can set that. Mostly in the playlist URL:
http://iptv.foo.bar/?user=xxx&pass=yyy&output=m3u8
http://iptv.foo.bar/?user=xxx&pass=yyy&**output=ts**
Helps mostly.
Thanks. I got a provider that seems good.
I need to delete the tuner. Why is there no red X
Would it be possible to add an authentication screen to the interface?
Where exactly do you want to delete the tuner?
I’m currently having an issue of xTeVe crashing upon refreshing the M3U and XML. Does anybody know what could be causing this?
Same here. As I wrote earlier I originally thought it was the auto update but turns out it still happens after turning it off. Viewing the service status I can see that the last status is always the refresh.
Yeah I tried setting a time a couple of minutes after pressing save and it crashed exactly on time.
I downloaded your tool today and wanted to install everything.
But I do have some problems.
first of all, I can’t assign the stations. Every time I go on mapping and want to assign a station and then go to save, the tool crashes and it doesn’t work anymore.
What could be the reason?
Everything is installed on Windows 10 and the server is the latest version.
