xTeVe - IPTV for Plex DVR
Yes with XMLTV, you have to delete all tuners in Plex and set up a new one. When setting up it is possible to specify an XMLTV file.
If you change the EPG source to XEPG in xTeVe, then you can also sort the channels in xTeVe before. Also several XMLTV files are possible.
Hello mermel can i use local paths for logos on windows? i tried but does not work, there is a way to do it?
No, that will not work, the URL in xTeVe will be passed to Plex. Plex downloads the logos from the internet.
Ok no problem i hv instaled a local webserver with my own logos, i love the mapping tab. I read that there is an error with the shows categories and all the shows are shown as movies, i use webgrabplus to get the epg, can i do something to fix it or i just wait for another awesome version of xteve :slight_smile:
I dont kwon if its the same problem but PMP windows 10 on livetv tab the browse all button doesnt work and sometines stuck PMP on the backscreen.
New functions will be added to the mapping function. That was just the beginning. But the categories will not be able to classify xTeVe 100% correctly. Currently xTeVe copies the program information for the desired channels from your XMLTV file and creates a new one. If enough people would write to their XMLTV providers what’s missing, maybe something will change. xTeVe will not be able to replace an XMLTV provider.
xTeVe is far from finished yet, currently I am working on a new big feature in xTeVe.
Information on this, coming soon in the Discord channel.
What is PMP, or do you mean PMS? Post a Schreenshot, I do not know exactly what you mean.
I mean Plex Media Player the plex client for windows. I use Webgrabplus and the file generated has the categories:
<date>2001</date>
<category lang="es">Series</category>
<category lang="es">Comedia</category>
<icon src="http://www.movistarplus.es/recorte/n/caratula4/F3558003" />
<country lang="es">EE.UU</country>
I can not wait to see the new features, great job man.
sorry but i cant find and documentation… how i can install it on linux? i already put the bin file on a directory what i must or something to make it work…??
hello valan do this on debian based distro ā€œsudo chmod +x ./xteve.binā€
Thank you :slight_smile:
Plex has fixed categories and Spanish are unfortunately not there. Basically, they should be in English. As far as I know, Plex translates it into the right language.
Look at this: XMLTV & Categories
I do not know the Windows client, so what exactly is not there?
ye i found it i do mistake now i see how it works… thanks
I’m currently having issues with the wrong channel logo showing up for some channels. Also, there seems to be two channels for the same one with certain ones. Would this be xTeVe or Plex itself?
The EPG file seems to be correct but it isn’t in Plex.
Which EPG source do you use, Plex EPG, XMLTV or XEPG ?
I was using XMLTV but the XEPG seems to work properly.
Actually no… ignore that, the logo is still wrong with some! The logo shows up correctly in the XEPG. It seems to show the number 3 for one and 3e for the other?
Please take a screenshot so I can understand what you mean.
How do I install xTeve on a Linux machine?..
cd /path/to/xteve/
chmod +x xteve
./xteve
never seen .dms file… how do I use that?..
.dms is a safari bug. Just ignore it or use another browser.
do I wget the link adress from site?.. when I get a file xteve_linux…
