xTeVe - IPTV for Plex DVR
On the site are download links, which you can download with any program that understands HTTP.
If I use chrome as browser… on my Mac and click on Osx link… it downloads a xteve noname file. same with linux…
Not with me
I get that file… but how do I use it… with what?.. how do I install…
As I wrote above, the commands are the same for OS X, Linux and FreeBSD
Thanks! sorry :slight_smile:
The top one should show the ITV logo and second one should show the Channel 5 logo.
Please look in the xteve.xml file, if there is the logo for the channels.
channel id=103
channel id=105
<icon src="http://logo.jpg"></icon>
I can’t find the XML file within the xTeVe folder…
if you use XEPG, the file is in the tmp folder, which you must also specify in Plex in the XMLTV settings.
Apologies, I have now found this. Yes the icons are shown correctly in the XML file.
hi, i have a problem with epg, this is 1 hour earlier maybe problem with time zone how to fix this?
Restart Plex, maybe old logos are still in the cache.
Please send me your XMLTV file, I think Timezone there wrong or missing.
Yeah I’ve tried a couple of times but it doesn’t seem to update. Seems strange that the logo seems to be changing.
You can also change the logo URL in the mapping settings in xTeVe. Then you have to update the EPG data in Plex, maybe that helps.
How do I get xteve to autostart on ubuntu?
hi, nice job, you can without epg in argentina there are no complete guides
I think Plex EPG is not complete in any country, XMLTV is the solution for missing data.
thanks, I think it will take me a while to work on this
