xTeVe - IPTV for Plex DVR
Hi I only. Have a nvidia shield and did not see how to install this on an android device. Is there a way?
Someone has gotten it to work, but how exactly he did it, I do not know.
Not sure if you have a PC or not. If you do, you can xTeVe on your pc, and you shield PMS will use it
Hi @marmei,
For IPTV I use a private one as it is the only way to watch Spanish TV as I live abroad and the VPS provider is Wishosting.
I’ll try from my NAS to see if the issue comes from the IPTV provider or the VPS side and let you know.
Regards
When filtering is there a way I can get it to ignore all with VOD in the channel name?
in which group are the VOD channels?
xTeVe is accessible via all IP addresses that your server provides.
Is it possible to put a login/password in the website.
Otherwise everyone can see my link(s) of the provider.
It will be possible in the next version.
Thank you for the answer. Looking forward the next version. Any idea when it will be released?
I have some inconsistent behavior of subtitles.
There are subtitles in the streams (checked with VLC) usually dvb subtitles.
Some channels in live tv however doesn’t show them and some show them. Really strange?
Any ideas what the problem is?
Xteve just passes the stream to plex tuner so maybe it’s a plex problem?
Some time ago I lost the channel log:
I noticed that despite the channel loaded, the channel buffers periodically.
Qnap is a fun device.
how do you install xTeVe on FreeNAS 11.1
Update will come in a few days
Yes, that’s a plex problem
Use XEPG in xTeVe, that makes a lot easier in Plex.
I just wished Plex could get there acts together and fix the most elementary functions.
They have always put us subtitle user in the bottom in the barrell.
I guess it would be the same if I hook up a dvbt tuner or similar.
I’m trying to use XEPG, but I get the following error:
2018/09/08 12:53:49 [xTeVe] [ERROR] XML syntax error on line 1: invalid character entity &ļæ½ (no semicolon) -
The EPG works in other clients.
xTeVe adheres to the XML specifications. It looks like your XMLTV file has invalid characters.
What seth in the first line of your XMLTV file?
Can you open the XMLTV file in your browser?
I just use it and it was all right. After some restart Qnapa stopped working Xteve, I made a restart and I added the decoder again since then I do not have icons.
