Do you mean the channel icons? xTeVe takes the URL of the icons from the XMLTV / M3U file and passes them on to Plex. Check if the icons are in the xteve.xml file.
Yes. Some time ago everything worked. Today I do not have program icons. I’m checking the XMLTV file.
Ok, it’s 27mb compressed with gz, and 211mb uncompressed.
The first line is:
<?xml version="1.0" encoding="UTF-8"?>Yes, I can open it in my browser.
Can you send me the file? Google Drive or something
Hello
How to install it on my Western Digital PR4100 NAS
Is this possible?
does anyone know how to edit/add/remove channels to the iptv setup in plex? I have to remap channels when I set it up so its a pita. I had mapped a channel that now needs to change and would rather not do it all over again. Figured this is sitting in some config i could manually edit…
click on 45 enabled
You have to activate it so Plex knows which channels you want to have in the guide. Activate left and select the guide on the right.
For this, someone has to create a 3rd party app from xTeVe. Maybe someone knows more in the WD forum.
How can I choose my own epg guide that I have setup in the xteve app?
Now with the dvr setup I have to choose one country list but I have a iptv mix from different countries and want for more countries epg.
You have to remove all your DVR tuners in Plex.
With the setup wizard of Plex DVR you can then specify the XMLTV file of xTeVe.
Finally got around to doing this.
However, I went to upload the xmltv file (given to me by my iptv provider) and xTeVe gave me the auto generated extension to put into the the plex DVR setup, but none of the channels are listed correctly. Any reason you could explain as to why this happening?
Which EPG source did you specify in xTeVe (settings), XMLTV or XEPG?
Trying out vader streams and used their links for the setup info and selected XMLTV in the setup menu in Plex.
Change the EPG source in xTeVe to XEPG and everything will be fine
This allows mapping the channels in xTeVe, xTeVe creates a new XMLTV file, which you then enter in Plex.
In the next update of xTeVe then much more.
i want to try it, but i dont get it working…
xTeVe is running and has a m3u list. But when i try to add the tuner, it doesnt work. The tuner is not listed. When i try to add it manually, the tuners appears for 1 second an then it is gone again. Trying to connect again, doesnt work either. I just see my AVM FritzBox DVB-C server.
Someone has an idea for me?
Do not worry about it. Just keep going.
When you enter the Tuner manually, you can press “continue”.
